Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Extremely high chlorine-What was I thinking?
    Jun 2014
    Hulmeville, PA
    42
    Unhappy Extremely high chlorine-What was I thinking?
    Hi, I made a rooky mistake and dumped 13 bottles of bleach into my pool without testing the water first. When I opened the pool, there was obvious sign of algae so I added bleach yesterday and had my mom just dump several bottles of bleach over the course of today until I got home to test the water. I put in 6 bottles yesterday and my mom added 7 bottles today. (Clorox 121 oz. 8.5% strength from Sam's Club)
    Well, now that I have tested the water I am a bit scared that I might have royally messed things up.
    FC-87.5 I added 175 drops before a color change and still there was a slight pink to the water
    PH-more than 8.2
    TA-50
    CH-125
    CYA- black dot somewhat/barely visible at 10
    What should I do? Is the following correct
    Use 26 oz of muriatic acid to lower PH and then add 127 oz baking soda to raise TA
    AG 15x30 wall height 52" - 13,500 gallons install 05/2002
    Astralpool Millennium Series 2000 sand filter 19 1/2 HP
    2.0 HP Pump
    Agua Heat electric heater
    TFT-100 test kit
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Extremely high chlorine-What was I thinking?
    wow that is pretty high, but your CYA being at zero, if you get direct sun daily and have algae to kill
    should lower itself over a period of weeks.
    sounds about right on the acid and baking soda. I would add half at a time then test the water.
    Dolphin E10 Cleaning Robot.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Do nothing to the pH. High FC - and yours is - affects the dye. You can;t trust that pH reading.
    Do nothing to the TA yet. You don't have a plaster pool, so there's no danger of etching the plaster.
    For the chlorine, I'd say: wait.
    If the liner's going to bleach out, it's good bet it already has. With hardly any CYA, you'll lose a massive amount of FC just to the sun. I'd guess as much as 50% per day.
    Take advantage of the high FC and brush that pool. Just wear disposable clothing in case you splash yourself.
    And don't do that again.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    oops ya I left out what Richard said, don't do anything until you are back to a normal level.
    PH test is useless if chlorine is 10ppm or more.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    FC 87.5? We have a new record I think.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2014
    Hulmeville, PA
    42
    Thanks so much!
    What are my chances of being able to use the pool on Monday for the holiday?
    I found this site last year and have probably read just about all the pool school documents at least twice and really should know better. I was trying to rush the process!
    Also, is it okay to put in my Aquabot Sport into the pool to vacuum? Or would the high chlorine level damage the machine?
    2.0 HP Pump
    TFT-100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If need be you can use chlorine reducer to get FC down to swim level, if the pool is otherwise clear and free of algae.
    p.s. if your local pool store does not have Sodium Thiosulfate based Chlorine reducer, you can also use common 3% hydrogen peroxide which typically sells for under $1 per QT at dollar stores, the downside is you get about a 1-1 effect volume wise with bleach using the 3% hydrogen peroxide method, so you might have to visit several stores to buy enough.
    Ike
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    If you have full sun daily until monday it's possible.
    generally you shouldn't swim in above "shock levels" and if you do swim
    around the shock level or a little below, your swimsuit will likely pay a price.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might also want to get some CYA in there which will buffer the FC some.
    I would keep the robot out until the FC comes down a good bit
    The CYA will of course slow the FC burn off rate too, so there is a trade off
    May 2015
    Central Illinois
    41
    Wouldn't it be best to get the chlorine down to prevent further damage to the liner? I used Sodium Thiosulfate when I goofed to 26ppm and it works very quickly.
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I think we are mostly working around the theory that much of the damage is already done and the FC is likely declining on its own
    May 2015
    Central Illinois
    41
    But if it only goes down ~3 to 4ppm per day, It could be high for weeks. o.o
    Jun 2012
    Rochester, NY
    247
    I do feel for you, but wow. I can't imaging adding 175 drops and keeping track.
    I'd love to know the color of the Chlorine Block test.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    Jun 2014
    Hulmeville, PA
    42
    I should have taken a picture. It was a very deep red.
    I just saw in another post that baquacil oxidizer reduces chlorine. I am thinking of getting a bottle. Any thoughts?
    https://buckstovepoolandspa.com/shop...oxidizer-shock
    2.0 HP Pump
    TFT-100 test kit
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Ouch...I thought mine was bad several years ago at 47 after the "pool store" told me to dump in a 25 lb container of dry chlorine which by the way did bleach out my liner.....that was also my last trip to the pool store!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Donldson's Avatar
    NW Ohio
    2,885
    It will work if you really need to use your pool. All it is is hydrogen peroxide, so if you can't get the oxidizer locally just get a few bottles of peroxide from the store.
    Honestly, if you don't plan to swim for a few days then the sun will burn it off quickly enough that it might not be worth the cost. As was said before, any possible damage is likely already done.
    Have you measured it today?
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by borjis View Post
    If you have full sun daily until monday it's possible-your swimsuit will likely pay a price.
    And anyone that uses hair dye. Green hair could be the new rage!
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Quote Originally Posted by 4knights View Post
    Just for clarity. high chlorine doesn't cause green hair, copper in the water does.
    Now what it might do to that pretty new dye job, I don't know....might bleach it out?
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    4knights's Avatar
    NE Kansas
    419
    I have tested for copper and had none but the girls hair still turned green, must have had that copper in the blonde dye
  20. Back To Top    #20
    Jun 2014
    Hulmeville, PA
    42
    I didn't test it today. I will first thing in the morning. While I was at work, I had my mother backwash to dump water and then refill. Unfortunately, we only get about 5 hours of direct sun on our pool.
    2.0 HP Pump
    TFT-100 test kit
