Thread: Help Setting Pump Speed
    Nov 2014
    Chico, CA
    2
    New pool owner. Trying to figure out all this stuff.
    To save energy, I just had a new Pentair Superflo VS pump installed. This is the new 2015 version #342001. Is there a simple way to figure out what speed to program to clean the water and how long to run at that speed?
    I don't have any features, and the sweep has its own pump.
    I would like to run the filter as little as possible to maximize energy savings. I would like to just run it at the speed that maximizes efficiency and minimizes run time. Does'nt need to be exact, just a ballpark.
    20,000 gallon inground gunite pool. 1.5hp Whisperflo Filter Pump. Pentair FNS PLUS DE Filter 48 sqft.
    Re: Help Setting Pump Speed
    You want the lowest speed where the skimmer(s) still skims effectively. I would try around 1400 RPM to start and adjust up down from there and see how things go.
    Four hours of run time is enough for nearly all pools.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I love my VSpump. It is cheap to run, quiet, you can pump however much water you want. Our one pump runs the filter, solar and waterfall. Here is what I do.
    1100 rpm to filter, skimmer and SWG. I get good skimming action the SWG is happy and it only draws 150watts.
    When solar heat is available it kicks up to 1950 rpm and draws @500watts and gives plenty of flow through the solar panels.
    I usually run 1500 to run the waterfall and/or extra suction for the bottom drain for brushing.
    I had to do a little experimenting to find the best speeds to run, but it is as easy as pushing a couple of buttons.
