Thread: Does the CYA Reagent R-0012 go bad?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Got some odd results and cannot explain them so over to the experts...
    New plaster pool being started up over last 2 weeks.
    Checked this morning:
    FC 2
    pH 7.7
    TA 30
    CH 325
    CYA 0
    Added 64 oz Mutiatic Acid to start bringing up CYA
    Left it for a couple of hours
    pH 6.8
    CYA as near to 0 as I can tell.
    I filled to bottom of label, added R-0012 to top of label, shook for 30 sec or more.
    Slowly filled cylinder and I can still clearly see the black dot.
    Left it for a few minutes, still visible.
    Very little precipitate.
    The pH swing shows that the acid is there, but not showing up in CYA test.
    Could my R-0012 be bad, new kit and I have not got a reading with it yet?
    I'm obviously heading off to get some Borax to raise the pH to a more reasonable level.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    St. Louis
    12
    Re: Does the CYA Reagent R-0012 go bad?
    MA lowers PH, which your test proves. You need stabilizer to raise CYA.
    25k gallon, IG gunite, Plaster/Pebblesheen (new in August of 2014), Sta-Rite 300lbs sand filter, TF100 Kit
    22,542
    R-0012 is a calcium hardness reagent. The CYA reagent is R-0013. It's a pretty stable reagent so unless it's very old I wouldn't suspect that it's bad.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Sorry, meant 13.
    But using Muriatic rather than Cyanuric acid is my senior moment for the day.
    Thks
