Thread: Pool is not losing Chlorine?
    Jul 2014
    NJ
    46
    Hi everyone, my pool has not needed chlorine for the past 2 days. Is this normal? It has been about 65 degrees and cloudy, and at night going down to the 50's. All my numbers have been great. Was having trouble getting my CYA up, but got I up slowly and its good now. Just want to make sure that its normal. Thanks!
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    Re: Pool is not losing Chlorine?
    That is a little on the unusual side, but not unheard of.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What is your water temperature, algae, etc. grows slower in cold water, combine low water temperature with possible low sun exposure and you get low FC consumption
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Gloomy days really slow down chlorine loss.
    Two questions: 1) are you testing it using colormatching or FAS-DPD; 2) Are you using pucks to chlorinate?
