Thread: pool calculator
    May 2015
    pittsburgh pa
    62
    pool calculator
    Is it possible to save the values I enter as goal so that I dont have to reenter each tim?
    11,000 gal (21' round) AG
    DE EC40
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: pool calculator
    If you select trouble free pool as your method near the bottom drop down box it will save your goals. You just have to enter current readings
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Re: pool calculator
    If you allow cookies it will save the numbers in the goal column automatically.
    May 2015
    pittsburgh pa
    62
    Re: pool calculator
    Quote Originally Posted by Azgirl71 View Post
    not seeing the drop down box you reference..
    DE EC40
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: pool calculator
    Quote Originally Posted by 21 footer View Post
    The very last row in the table. It's yellow and it's labelled Suggested Goal Levels
    May 2015
    pittsburgh pa
    62
    Re: pool calculator
    Gotcha, thanks!
    DE EC40
