Results 1 to 9 of 9
Thread: Pool Chemicals Left By Previous Owner
    May 2015
    River Falls, WI
    124
    I have chemicals left by the previous owner I'm trying to sort out what to do with...
    One in particular is a product by Doheny's called PH Plus. http://www.doheny.com/poolsupplies/PH-Plus.html
    I have a pail of it. Is it worth keeping/using? Will this product raise TA too?
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Re: Pool Chemicals Left By Previous Owner
    PH Plus is what we call soda ash. It is fine to use. It raises the PH a lot, and the TA some.
    May 2015
    River Falls, WI
    124
    Quote Originally Posted by JasonLion View Post
    Thanks! That's helpful. I figured that it was an ok product I just wanted to be sure I wasn't in for some side effects of raising my TA way too much.
    I also have a pail of 3" ProTeam High Tech Tabs: http://www.proteampoolcare.com/index...igh-tech-tabs/
    Is it worth having pucks that contain CYA in them? If I used them once in a while if going out of town etc how much CYA can a puck or two do to a pool in a few days??
    Donldson's Avatar
    NW Ohio
    2,898
    Pucks are great for going out of town and as long as the bucket is closed tightly you should have no problem keeping them for a long time. Just make sure you keep in mind the CYA increase when you use them and verify your level occasionally to be sure you are keeping your FC high enough for your CYA.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Those specific tabs you linked will add CYA, but they also have the equivalent of borax in them so they should somewhat counteract the pH decrease that is sometimes seen when using trichlor tabs. They have no metal "enhancements" so that's a good thing. Perfectly fine to use when away from the pool, knowing that they'll raise your CYA a bit. In your pool, each tab will add about 2 ppm of CYA, assuming they are 8 oz. tabs. You can see this yourself in the Effects of adding chemicals at the bottom of the Pool Math page.
    Isolated Spa - 345 Gallons
    May 2015
    River Falls, WI
    124
    Do they sell pucks that are cya free and recommended for pool owners sticking to tfp methods?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by wrems View Post
    Nope. All the pucks are chlorine bound to cya. Check out poolmath to see how much cya each puck will add to your pool.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Feb 2014
    Central Minnesota
    5,080
    Some pucks are stabilized by calcium, these are called CalHypo tablets. They add chlorine and hardness (CH) to your pool. CH also will build up if you use these tablets over time. Plus CalHypo tablets break down/fall apart/get slimy so must be used only in a floater and NEVER combined with trichlor tablets. ALL solid forms of chlorine add something to your pool that can eventually cause problems.
    Quote Originally Posted by JVTrain View Post
    Right, but they dissolve in minutes rather than days, so they can't be used in a floater the way trichlor pucks can.
