Thread: Calcium Hardness and Pool Heaters
    OK i'm buying a Propane Pool heater. I currently have vinyl pool and thought i don't need any CH because i don't have plaster anything.
    Does a copper or cupper nickle exchanger require a certain level of CH?
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    Re: Calcium Hardness and Pool Heaters
    No, the heat exchanger isn't at any risk at all from low CH levels.
    On the other hand, there is some chance that low CH could cause problems with getting them to honor the heaters warranty coverage, should that come up.
