Thread: Multi Port Valve Repair
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Exclamation Multi Port Valve Repair
    So I am going to be taking apart my MPV tonight to see if I have a spider gasket issue. Can someone school me on the proper way to do this? I remember reading somewhere that you have to have the valve set on a certain setting before disassembling and reassembling.
    Reason for issue: LOTS of sand in my pool after start-up. Laterals and internals of filter all replaced last season. In the process of taking this apart to check the laterals to see if they're cracked AGAIN. Hopefully it's just a lateral and not the hub the laterals screw into.
    Step #1 & #2 before a replacement!
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Multi Port Valve Repair
    Here's the link to the Hayward manuals: http://www.hayward-pool.com/shop/en/...ls#FiltersSand
    Is it a top or side mount multi function valve?
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Side mount, that manual doesn't have MPV's in it.
    Lynzizzle
    Apr 2011
    Murrieta, CA
    2,360
