Thread: Will this cause a problem to add to my pool?
    Jan 2015
    Palm Springs, CA
    29
    I recently had to have my pool bead blasted and refilled to remove heavy scale above the water line. My CH was 1100 before the pool drain and now is 175.
    The guy that did the bead blasting gave me 4 bottles of this product, All-Clear Stain & Scale, and he said to put a bottle in every three months to help so the scale will be easier for me to clean. Our fill water has CH of 175 and TA of 150.
    Anybody have any experience with this product?
    Current test results:
    FC 6.0
    CC 0
    pH 7.8
    TA 130
    CH 175
    CYA 70
    Salt 3500
    Pictures:
    Here is what the scale looked like before removal (White above water line). The tile is blue under that.
    6640 gallon outdoor in-ground 8x26 pebble pool, 3'-5' deep, Pentair IntelliFlo Variable Speed pump, Jandy CL580 Cartridge Filter, Jandy AquaPure 1400 SWCG
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Will this cause a problem to add to my pool?
    Do you have a metals problem? I can't find the exact SDS (safety data sheet) listing the exact chemical make up of that product, but products like it with similar names are metal sequestrants containing phosphonic acids/HEDP. These products help keep metal ions in solution, rather than staining your pool. Not sure this product really does anything for preventing scale. Keeping your CH near recommended levels and not letting your pH get too high prevents scale.
    Isolated Spa - 345 Gallons
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Scale will only form when you have high CH and high pH. Since you have a pebble pool you need to keep your CH in the 250-350 range. Right now you don't need to add anything to prevent scale. Just raise the CH to the recommended range and don't use any calcium hypochlorite products. Eventually your CH may get over 400 from the fill water if you don't have much rain in your area. Once the CH creeps up, you can keep the pH 7.0-7.2 range to prevent scale from forming.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Nope, never have heard of it.
    Get the chemistry under control and watch the CSI. It really isn't all that difficult to prevent scale up to about 800 CH. And I would hesitate to add any CH. Just from evaporation, you'll be in range quick enough. And I know it gets hot and breezy in Palm Springs.
    Jan 2015
    Palm Springs, CA
    29
    This was my thoughts also. Hate to add anything unless really needed. Thanks
