Results 1 to 7 of 7
Thread: CYA level??
    Mar 2013
    TN
    178
    CYA level??
    I have been running around 50-60 on my cya ever since pool installation. Water looks great and chemical balance has been easily maintained. The recommended level is 70-90 I think, should I be trying to increase my cya or just let it ride?
    What happens other than faster escaping of FC when your cya is on the low end?
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA level??
    Because you have a SWG it should really be 70-90. I keep mine around 75. When it is lower your SWG has to work harder and it decreases the life of your cell.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Re: CYA level??
    70 to 80. We don't recommend going over 80.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA level??
    The chart says 70-90 so that is where that came from.
    Edited. To say I stand corrected. It does say 80, but I know I have seen 90 somewhere on here.
    Lisa
    Re: CYA level??
    What chart says 70-90 for CYA?
    Mar 2013
    TN
    178
    Re: CYA level??
    The last thing I want is to blow a $500 SWG cell, I will start to increase my cya this afternoon.
    Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA level??
    I edited my post. I double checked and it does say 80, but I swear I saw 90 somewhere on here. If I find it, I will let you know.
    Your welcome.
    Lisa
