Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: How much does a new pool cost?
    May 2015
    pearland tx
    1
    hi! im a lurker here i was just wondering how much does it cost you for everything? i am planning to put a pool in my house but i have no idea where to even budget how much to spend. lol
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How much does a new pool cost?
    Welcome to TFP!
    First, you have to decide what kind of money (ball park) you're willing to spend and then what sort of pool you have in mind. Lots and lots of options. Enjoy the forum!
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    As Patrick said, a range of budget probably comes first. You can get into an inexpensive above ground for less than $1,000 or fancy custom in-ground pools can easily go to hundreds of thousands of dollars without trying too hard.
    Support the site
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Welcome to TFP! I see you live in Pearland so I'll take a stab at your cost question for an IG pool. From what I've seen in most standard (cookie-cutter) neighborhoods in our area, IG pool sizes range from 10k-40K gallons. "Bare bones" minimal decking no water feature except for maybe a small hot-tub on the smaller end is about $35k. On the larger end, still bare bones $50K is a good estimate. The cost escalate quickly and drastically with landscape, water features (rocks, waterfalls, coves/caves, slides), deck features (fireplaces, cabana's and restrooms), larger decking (surface type). Add $10-$100K+ for that. As you can see it's a tough question and the major cost is in the extras! Good luck, take your time and have fun with it.
    ..oh and how could I forget the outdoor kitchen?!..and you gotta have one of those that alone can run $30K!!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Mar 2015
    Las Vegas NV
    460
    Looks like there are several Texas builds going on right now. I'd reach out to someone near you and see if they wouldn't mind sharing their costs with you. In Vegas I've shared mine with several people and it's helped them with some decision making.
    I agree Patrick, first set your budget and then back into it. I had two budgets, one for the pool excavation, plumbing, steel, shotcrete, tile, minimum decking required by city, plaster and equipment. Second budget was additional 1,500 sq ft of decking, gazebo and two options for landscaping, bare bones and more than bare-bones.
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Jun 2011
    Carlsbad, NM
    172
    I have noticed that it is largely dependent on location. Two friends just had 25000 gallon gunite pools with spas built. One was 120k, the other 130k. I have seen similar builds in Florida go for 40k. My replaster was 14k, but I see some people on here have had it done for 6k or less.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    ^smracing is correct-location, location, location!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    For the Houston area, and Texas in general, Concrete inground pools of some type (Gunite, etc) are most popular, with fiberglass and vinyl following up as 2nd and a distant 3rd. I can't tell you why this is true, as here in SW Louisiana just 150 miles from Houston the order of popularity is the reverse, maybe it has to do with property values, or some cultural thing, or population density, or even building codes, who knows but a quick google search showed that the top 3 hits for vinyl pools houston, seem to specialize in liner replacement for older pools and not building new ones. I state all this to give you a bit of context when you are looking online since Gunite construction cost vary considerably, but probably due to volume of use are relatively low around Houston.
    Oct 2014
    San Antonio, TX
    449
    I live in the San Antonio area. I recently went through the process of getting price quotes on a basic IG 17X30 3.5 to 5ft deep pool. ~600 ft of basic concrete decking and the quotes ranged from 42k to 51k.
    Update: I should have mention that was gunite/shotcrete quotes.
    For some reason in San Antonio, the fiberglass was a little higher priced than gunite. Not a lot, but I always assumed FG would be less
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    It's also worth noting that the cost of an in ground can be broken down from low to high (build costs) based on the type of basic in ground installation.
    Lowest to highest is:
    Vinyl lined, fiberglass, gunite/concrete.
    Dolphin E10 Cleaning Robot.
    Jul 2014
    Hope Mills, NC
    569
    NC mid state, complete including extra wide concrete, replacing sod and some average landscaping $30k
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2015
    Fullerton, CA
    636
    32x18 freeform with 8' spa, 5' deep, pebble sheen finish, good equip, all plumbing and electrical stone coping, tile. 160 SF concrete, 950 SF paver decking, equipment walls, block walls gate, and demo about $85k in So CA.
    sorry left some stuff out. Pool equip, coping and tile about $53k
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Hi Neighbor (relatively)! I'm in the middle of our pool build. The gunite has been shot, plumbing and electrical completed, and the tile guys are outside laying the coping as I type. I spoke to 4 area Pool Builders and their quotes were in the same ballpark as Jagger and Titan (surprised with the So CA quote).
    I started with a budget lower than I knew I could do (about 10K lower) - hoping I might get lucky or at the least, allow myself some room to upgrade. That strategy worked fairly well. I think most people would agree that you can expect to add things as you go along - some expensive, some not so much. I think I am a little over my upgraded budget, but thankfully I don't have much time left to do any more damage to my bank account. It seems most people do end up spending more than they swore they would! You just get excited and you learn more as you go. I have read 1 or 2 cases where the people had great discipline and stayed on target with their budgets.
    Oh, I set up 3 budgets rather than lumping them all together. Pool, decking, landscaping. I knew decking and landscaping could be shaved down and completed over a year or so. But many of the pool goodies need to go in at the time of the build.
    You also need to consider your current and future situations - as best you can. For me, I've waited decades to have my own pool. This is my first and last pool, so I'm having fun. But there are many other situations that put a different slant on spending. For example, if you think you will be moving - that's a big one. I would never splurge if that was my situation.
    Good luck! And welcome. TFP is awesome! Take care. Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jan 2015
    Austin, TX
    1,095
    It also depends on what type of soil you have and the slope of your yard. I have both rock and a very sloped yard and I blew way past my initial 60k budget with no spa. So far I am about 5k above the original quote by making the pool slightly bigger, upgrading the filter, adding auto fill, etc...
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Howdy neighbor, I'm also in Pearland in Shadow Creek Ranch. In ground pools in our area cost anywhere from 40K on up depending on what features you want and your yard. We recently had our pool built last year. Click on my build thread below to see.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Jul 2014
    Independence, KY
    234
    There can be some additional/hidden costs outside of the actual pool, because many builders don't quote fencing, electrical & a winter cover, those you have to do on your own. Depending on yrou area and selections, electrical probably around $1500, fencing about $10-$15 per linear foot installed & winter cover $1200-$2000.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    I'll sell you mine for $600,000. And to sweeten the deal, I'll throw in the house.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just to show what different markets are, one of the local pool builders / pool stores here is running a special on an 18x36 basic traditional rectangular vinyl pool with 3 ft of concrete decking for $19,995 (price does not include permits or electrical)
    Jul 2014
    Independence, KY
    234
    Quote Originally Posted by Isaac-1 View Post
    I think that type of deal exists in most markets. Typical add ons are going to be:
    $750 for a light
    $200 for a ladder
    $2500 upgrade to larger size 18x40
  20. Back To Top    #20
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Vinyl seems most popular here in SE VA. When I was shopping back in 2003, a nice size (around 20x40) ran in the low $20k range installed, including 3ft concrete decking all around, safety winter cover, automatic cleaner w/booster pump, SWCG, and of course pump/filter etc.
    We added some extra decking and landscaping, so that drove our price up some.
    I'm not sure what the going rate around here is now.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
