Thread: Skimmer question
    Jul 2010
    Apopka, Fl
    31
    Skimmer question
    Hey guys, I have a Jandy valve for my skimmer. As I stand by the skimmer basket I watch as some debris floats past as some gets sucked into the skimmer. If the debris is hugging the wall it will go into the skimmer. If it's 2 or 3 inches away, it floats by. Now, when the pool was installed 10 years ago, the pool guy said to never open the valve more than a 1/4 of the way. I probably should have questioned this before, but lately I've been getting a lot od bugs that make their way to the bottom. So, my question is, should/could I open the valve all the way to allow for more suction? As it appears the MD is only for circulation.
    Inground 15x30 oval, plaster, 11250 gallons(?) with pool cage...jandy 100sq ft cartridge filter... SWG...Taylor K2006 Test Kit
    Located Apopka, Fl...Orlando area!
    38,271
    Re: Skimmer question
    That should be fine to open the valve.
    You have a weir on your skimmer?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I probably have 85% of my suction to the skimmer. The main drain is mostly just to eliminate the temperature stratification.
    I put it to full drain when I'm brushing, so that as stuff settles, it hopefully gets pulled in there.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    ditto
    Jul 2010
    Apopka, Fl
    31
    thanks, Jason...yes I have a weir
    thanks, Richard. Open it is!
