Results 1 to 14 of 14
Thread: What is this white stuff floating?
    Jul 2013
    NJ
    4
    Hello all
    For the last 2 years every summer during this time and for the next three months I become an active reader of this site. I am eternally grateful for all the advice and clearing up water chemistry fundamentals. This year I am strictly doing the BBB method as I wanted to exhaust my BUCKETS of chlorine tablets/granules I bought being new to pool ownership.
    Opened the pool last week as water was mostly clear though I did see some dark spots on the pool wall in 2 places (not much). SLAMed it everything seems ok with spots disappearing. My question is regarding the white stuff floating in the pool (picture attached). This thin stuff dissolves when the water is touched/agitated so I don't see it when the pump is running. Otherwise the pool is clear and my numbers are for the most part ok. It sticks or surrounds around any debris if that's relevant. I have searched this site and read some posts pointing to algae but I am just not sure if I have the same problem.
    FC = 8.5
    CC = 0
    PH = 7.8
    CH = 220
    CYA=55
    ALK = 80 (side question- how do I raise it safely to 110 without impacting ph or should I just leave it as is?).
    Ancillary info: in NJ , lots of pollen and the cartridge filter keeps getting up 10psi every 2/3 days of the pump running 9 hrs/day since I opened a 8 days ago. I drained the pool 1/3 and filled it with city water when I opened to get the cya down from 100 last year due to use of chlorine tablets.
    Good day to you all!
    23K gallons in-ground plaster pool with attached spa.
    1.5HP Hayword Pump
    1.5HP pump for Polaris 380
    75sqft Cartridge filter
    406K BTU Raypack gas heater
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: What is this white stuff floating?
    looks like pollen to me, which could be bleached out white due to chlorine. is the pool in a screen enclosure? that could be holding pollen, etc until it rains and then you get a bunch of it in the pool?
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2015
    La Grange, KY
    37
    I'll be interested in hearing responses to this. I just finished my slam a couple days ago and have been doing the OCLT for the last two nights just to be safe. Everything is checking out, but I do have this white stuff floating on top once I turn the pump off. I don't notice it right away, but when I get home from work I see it floating around. I was just chalking it up to stuff in the air getting trapped in the water (pollen and the like) because of passing the OCLT 3 nights in a row.
    Kevin
    Sharkline Venture 16,000 gallon AG. SwimPro Voyager cartridge filter. Taylor K-2006 test kit.
    Mar 2015
    South
    18
    Looks like pollen to me too. The willow trees near my pool drop a lot of it.
    16x24 shotcrete pool with plaster; ~ 11,000 gallons; Hayward MaxFlo XL 1 hp pump; Hayward Pro-Series Top Mount Sand Filter; Hayward Turbocell SWG; Hayward ColorLogic LED light; Hayward AquaPlus Automation Panel; TF 100 Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Welcome!
    Go look at the parked cars, the patio furniture, and the windowsills. Are they covered with pollen and dust? Then so's your pool.
    Mar 2013
    CT
    349
    Yup. I have it too.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would just use the skimmer net and skim it off the top. I agree it is most likely pollen.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    I had similar looking stuff in mine when we removed our solid winter safety cover. I figured it was something other than pollen since the pool had been covered? Maybe not?
    17x35 Oval In Ground Vinyl Pacific Pool, Pentair Intellichlor IC40 SWG, Sand Filter, Pentair Kreepy Krauly Legend Pressure Side Cleaner, LED Lighting System, 16 Mil Clear Solar Blanket, TF-100 Test Kit
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Looks like pollen to me. When I used a skimmer sock about a week ago it had a whole coating of the stuff. Weird creamy color mush.
    Incidentally, when I used a damp towel to wipe the glass top table in my gazebo the other day, the buildup on the towel looked like the same exact stuff. It was just dusty looking (not like "OMG look at all this pollen!!") until I pushed the damp towel over it and then it gathered up just like the mush in the skimmer sock.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    I have some of this lately as well. Mine is coming from Dandelions. The little white fluff glides in the breeze and drops in the pool.
    My neighbor doesn't mow their huge back yard and they have thousands of dandelions...(thanks neighbor)
    Dolphin E10 Cleaning Robot.
    30,419
    I get this stuff, too, just a little earlier. I do not believe it to be pollen but something off my trees. We have a preponderance of White Oaks but I don't think it is from them. It'll go away in a couple of weeks and seems to have no affect on the pool's circulatory system.
    Jul 2013
    NJ
    4
    Thanks for all your responses . Seems the majority is pointing to pollen and I do have a HUGE white oak 30 ft away. Plus yes the entire deck furniture, pool deck, now grill has a yellow coating on it. Let's see if it disappears in a week as pollen count goes down. A wider shot of the pool ..
    1.5HP Hayword Pump
    Apr 2010
    Central NJ
    227
    I'm in NJ as well and I've had the same issue. Whenever I see that in my pool, I make sure to see something similar on the hood of my car, then I know it's pollen.
    PS: I also check to see if my wife has allergies
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Nice pool!
