Thread: Pool coping
    May 2015
    Middletown ny
    3
    Pool coping
    Planning to install 12 inch wide bluestone coping around IG pool. Pool has steal walls with liner. Wanted to know the beat way to set the stone. Using mostly 1ftx6ft pieces on rectangular pool. There is a 5 inch metal lip at the top of the pool wall and it has been back filled with stone level with the pool. Can I just glue the pieces in place using pl500 or some other adhesive on the metal lip, while letting the other half of the coping sit on the crushed stone backfill. Also what should I use for the coping grout. Any help is appreciated. Ps beyond the coping will be brick pavers.
    In ground pool 12x24. Steel wall, liner. Salt system. Heat pump
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    Re: Pool coping
    Sounds nice but I don't have a clue how to install with that scenario. I'm sure someone will be by with helpful advice.
    How thick are they, are they consistent and what type of surface will they have?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Middletown ny
    3
    Re: Pool coping
    They are 1 1/2 thick with flamed finish. They are consistent. I've seen them used as stair treads on porches a lot.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    Re: Pool coping
    That will be a beautiful stone. I can picture it exactly. Now to figure out the install method...
    May 2015
    Middletown ny
    3
    Re: Pool coping
    Fingers crossed. You have a fantastic pool. How do you like the auto cover?
