Thread: Losing FC with SWG on High
    Apr 2013
    Dallas, TX
    59
    I think my salt cell may need to be replaced, but you tell me what you think. I was recently SLAMming to get of some mild algae and I performed an OCLT, but forgot to turn my SWG off. Instead, with it running on high, I still lost like 5 FC overnight.
    The algae problem is cleared up now (OCLT passed thanks to many gallons of bleach), but I've been watching my chlorine levels slowly drop ever since, even with the SWG still running with a high %. It's showing a salt level of 3000, so it's not that.
    Perhaps it just needs a good acid wash. When I get some free time, I'll take a look at the plates to see if there's any calcification, but this seems like a strong effect for just a little calcification.
    I bought this house in 2013 and I know the pool was built in 2008, but don't know if the previous owners ever replaced the cell, so it's somewhere between 2-7 years old.
    ~15k gal IG pebble pool/spa w/ water features, Goldline ProLogic + SWG, 2x Hayward Northstar pumps, Hayward Booster Pump, Hayward 60sqft DE filter, 400k BTU Hayward heater, Hayward Viio Turbo pool cleaner, TF100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    Re: Losing FC with SWG on High
    If it's 2 it died prematurely, If it's 7 it had a long healthy life.
    Until you sort it out you need to stay on top of the chlorine with liquid.
    Support the site
    Jul 2014
    Peoria, IL
    389
    I would clean it with vinegar or MA before chalking it up to a total loss. But if you lost that much running at 100% there is an issue, no doubt. But if it is 7 years old, I would say you got a lot of life out of it.
    I assume that your cya and salt are in an acceptable range? My SWG likes 3200-3400. Not sure on yours or if that little off would cause an issue???
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    ffournier's Avatar
    Apr 2015
    Houston Texas
    43
    What SWG do you have? Does it have a cell light on it? I have an Intellichlor IC40. It has a green cell light that lights up when the cell is producing chlorine. If I set mine at 100% that light would be lit all the time. If you have no indication telling you that the cell is actually producing chlorine, your falling FC level is telling you it's not, regardless of were your percentage is set. I'm assuming you have cleaned the cell at least a few times sinse you bought the house?
    25K gal saltwater gunite and Pebble Tech plus built in spa. Features-Weeping rock wall, and fountains. All Pentair equipment. Main pump- Intelliflo 4/160. Feature pump- Intelliflo 2hp single speed. Aux cleaner pump-Pentair 1hp. DE filter, Pentair heater, Glacier GCP210 pool chiller.
    What is your CYA level? If CYA is too low the SWG won't be able to keep up with sunlight losses.
    Apr 2013
    Dallas, TX
    59
    Quote Originally Posted by JasonLion View Post
    CYA is 60. Salt is 3000, which is the recommended level for the Hayward T-15 iirc
