Results 1 to 9 of 9
Thread: DE in the pool
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    DE in the pool
    Things have been going really well for our pool for the past year so haven't had to post in quite awhile, but now have a small problem. I have always been the one in our household to backwash and take apart and clean our filter grid, being the more mechanically inclined and handy with tools of the two of us. Recently I have been suffering from arthritis and tendinitis in both wrists, so my husband insisted on taking over this chore. He watched YouTube videos, and although I asked him to wait until I could be there to supervise the first time, he went rogue on me and went ahead and did it.
    I returned home to a cloudy pool which I told him was DE, but he insisted that he had opened up the filter to check it and everything was fine. It seemed to clear within a couple of days, but I now know it was probably just settling to the bottom. This was three weeks ago. This afternoon I noticed small piles of DE on the bottom of the pool underneath one of the return jets. I opened up the filter ignoring the pain and saw nothing on the grids but dirt, no DE, and of course it was put back together incorrectly.
    I hosed off the grids, put everything back correctly and started up the filter again and added the usual 6 cups of DE. I then had my teenage daughter sweep the pool for me to get the DE stirred up to hopefully be pulled through to the filter.
    Finally getting to my question. On reflection I am wondering if I should not have added the usual 6 cups. The original 6 cups he added I assume is floating suspended and sitting on the bottom of our pool. As that gets pulled through to the filter will it overload it? Is there anything I should look for such as the pressure rising to know that this has happened? I assume we should sweep daily and not swim until everything looks clear.
    Thanks!
    Lisa
    19,000 gal aqua blue pebble sheen, 3.5-7 ft. depth, chiseled flagstone coping, spillover spa, raised back wall with stacked stone face including two columns and curved wall water feature with three 18" sheer descents, two bubblers on 5' x 10' suntanning shelf, Pentair IntelliFlo Variable Speed, Pentair FNS Plus 60 sq ft DE filter, Pentair Mastertemp 400K BTU, Pentair Legend, Rainbow 320 chlorinator (now unused), K-2006 test kit.
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    Re: DE in the pool
    We are also running the pool cleaner to help keep the DE stirred up. Any thoughts?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: DE in the pool
    Yes, you will overload the filter with DE. When one of these two happens, backwash again:
    1) Filter pressure jumps up 25% or more and flow decreases.
    2) Everything is vacuumed up and the water is clear.
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    Re: DE in the pool
    Thanks! I will keep an eye on the pressure and the water clarity the next few days.
    Jun 2011
    Long Beach, CA
    2,790
    Re: DE in the pool
    Do you have a manual vacuum? My thought is to not run the pool and let all the DE settle and then gently vacuum the DE with a manual vacuum once it has settled on the bottom. Once the DE is suspended in the water it will take a long time for all of it to make it back to the filter. When you turn on the pool to vacuum make sure the returns are not pointed down because that can stir up the DE.
    The next time the filter needs to be backwashed I would take it apart and do a full cleaning to make sure the filter has the proper amount of DE.
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    Re: DE in the pool
    We do not have a manual vacuum. If it does not clear within a few days I will get one and try that route.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: DE in the pool
    If you normally use 6 cups when you do a breakdown filter cleaning, you need about 4 1/2 when you just backwash the filter. So I would just watch the filter gauge and backwash and recharge it w/ 4.5 cups ech time the pressure rises, until it's all cleaned up.
    chiefwej
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    Re: DE in the pool
    I use 6 scoops for a backwash, and I believe it is 9 scoops for a breakdown cleaning. Since I broke it down and washed the grids and then just added 6 scoops, it might not be so bad. The filter pressure after cleaning was at 11 or 12. I will watch it until it gets to about 15 and then just do a regular backwash.
    Richard320's Avatar
    Jan 2010
    19,051
    Re: DE in the pool
    I'd ask if one of the neighbors has a manual vacuum and a hose you could borrow for half an hour. Suck that stuff off the bottom and get it into the filter where it belongs.
