Results 1 to 9 of 9
Thread: Leslie's FC test
    May 2015
    Lafayette Hill, PA
    23
    Leslie's FC test
    Just curious does anyone know why when Leslie's tests water they suggest only 1-4 ppm for free chlorine? Is there a reason they don't take cya into account? This seemed like it was built into their system printouts also not just what the employee suggested.
    25,000, IG, Plaster, Hayward DE Filter, Jandy Pool Pump, 2011 install, No SWG
    Donldson's Avatar
    NW Ohio
    2,916
    Re: Leslie's FC test
    You will not find a pool store that recognizes the FC/CYA ratio. There are several possible reasons for this, it could be innocent lack of knowledge and following obsolete federal guidelines. It could also be a bit less innocent and that recognizing the FC/CYA ratio would mean selling less trichlor, algaecide, and phosphate remover. I personal believe the latter is more likely.
    This is one reason we recommend against getting water tested there, they will try to convince you that you are doing things wrong and try selling you products you do not need. Their testing is also suspect at best and some of us (me) won't even offer advice based on pool store testing. Might as well use a random number generator IMO.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2012
    Herndon, VA
    419
    ignorance, misinformation, dated information, and because it enables them to sell more junk you don't need
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    May 2015
    Lafayette Hill, PA
    23
    Ok I wasn't sure if it was some sort of guideline or them just trying to sell more product. My tf-100 is on the way so I no longer plan on going there.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I went into leslies yesterday just to confirm they did not have liquid chlorine bleach here in OK...
    The lady sitting there asking why the 500 dollars of chemicals she bought last week did not clear her green pool, they convinced her she had done it wrong and got her to buy another 300 dollars worth of ****... I waited about 5 minutes for her to come out to let her know but she was still being pool stored..
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by cowboycasey View Post
    Did you tell her about this website?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Can't convert all of them, but at least you tried.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    $800 and still keeping her head in the sand. Shame shame. I'd be filling the pool in with a shovel if I spent $800 at the pool store.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Leslie's FC test
    Quote Originally Posted by albel1214 View Post
    It's my understanding that pool store recommendations are based on the epa regulations of 1-3 ppm FC in drinking water. No idea why they still don't take CYA into account.
