Results 1 to 7 of 7
Thread: My test kit came today!
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    My new test kit came today. Here are my results.
    FC 5
    CC 1.5
    Total 6.5
    CH 300
    ALK 30
    CYA 50
    I must admit it was a lot simpler than the strips. It's is a more in depth kit but my results were definite. Thanks for the advice. Now what should I do to get them up to level.
    2017 bahama spa - serenity cove 82x82x39 stainless steel jets, 325 gallons,plasma ozone purification system,4kW heater, 2 pumps 6bhp each, acrylic surface TFtestKits TF-100 http://tftestkits.net.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: My test kit came today!
    What is the pH?
    chiefwej
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Sorry pH 6.8
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Congrats on tour test! PH needs to be brought up to 7.2, you have CC of 1.5 so there is something going on in there. Your TA is also low.
    How does your water look?
    You will need to look at the SLAM process in Pool School and use the chart to get you FC SLAM level for a CYA of 50
    After reading in Pool School about the ABC's of pool water chemistry, recommended levels and the SLAM process please post questions you may have.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Water is crystal clear.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    That is great! I will let someone else chime in since you have CC of 1.5, but in the meantime you can bring TA and PH up.
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Maybe try an Overnight FC Loss Test to see if anything is in there.
