Results 1 to 7 of 7
Thread: Procedure for raising pH?
    May 2015
    Reading, PA
    12
    Just finished SLAMing, and my pH has dropped slightly. Presently it's 7.2. So I need to add a little more than 5 lb of borax. How is this usually done? Pour it in the skimmer basket? Sprinkle on the water surface?
    Once it's in there, is the pump running sufficient to mix it in?
    My last TA reading was 80. Any idea how much higher I can expect that to be after this addition?
    I'm still dissolving the CYA in the skimmer. Will that affect this process at all?
    Thanks to everybody in advance, for helping the noob!
    AG 28700 gal (21x41 oval 4-6 feet deep)
    Pentair Warrior 88 DE filter/Hayward 1.5hp 2-speed pump
    Testing w TF-100
    38,301
    Re: Procedure for raising pH?
    7.2 is fine. Just leave it and it will rise on its own.
    Leave the TA too.
    The CYA is slightly acidic.
    You can see how to add chemicals in Recommended Pool Chemicals
    May 2015
    Reading, PA
    12
    Thanks for the link. I realized I had read it before and promptly forgot. Too much new stuff in my brain! I also was reading another thread and found a reference there to the very bottom of Poolmath, where you can check the effect of various "adds." What a great tool!
    So I don't need to camp on these tiny adjustments. I appreciate knowing that. I can't wait until I get a little more used to this and don't panic over every tiny change.
    Testing w TF-100
    Jun 2014
    Hartford, CT
    10
    As long as TA is right, I wouldn't add anything for pH. Aeration is the best way to manage pH. I started messing with chemicals for pH last year and spent a lot of money. Never got it right. After making a fountain, never had pH issue.
    May 2015
    Reading, PA
    12
    Quote Originally Posted by budalb View Post
    How did you make your fountain? I was looking at the commercial options, and the results seemed mixed. But everyone seems happy with the ones they make themselves.
    Testing w TF-100
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by DC608 View Post
    You need to be a little creative. Spend some time on the PVC isle at Lowes and then look at your returns. You should be able to come up with something.
    Support the site
    Jun 2014
    Hartford, CT
    10
    A piece of PVC of right size (1.5" for me), a thread connector to connect to the return, two 90 or 45 degree connectors, a hand saw, pipe glue. Then make whatever you need.
