Thread: Plunger valve leaking when the pump cuts off
    May 2015
    Winchester/Va
    2
    My plunger valve that is connected to my skimmer has a drip checked to O ring and it's fine. But everytime I turn off my filter and then turn it back on I get a no flow alarm code. I have to release air pressure from the leaf catcher. With having to do this I can't use the saltwater timer. HELP
    30,426
    Re: Plunger valve leaking when the pump cuts off
    Welcome to the forum.
    I cannot figure out your terminology. Can you post a pic?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    That sounds like Intex valves. Please add your pool info to your signature.
