Thread: 1000 gph sand filter?
    May 2014
    Washington State
    10
    I've searched a bit on this thread and can't seem to find any info. I was given a 1000 gph sand filter, a Bestway unit. I didn't know they even made them that small. I'm upgrading to a 16'x4' pool this summer, which I believe will hold appx 6000 gallons. Will this pump flow enough? I have a hard time believing it would due to the fact that my intex cartridge pump claims 1000 gph and I was fighting algae all last summer.
    Thanks in advance.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: 1000 gph sand filter?
    First welcome to the forum!
    No matter what filter you have, it won't resolve your Algae issue. That's strictly a Free Chlorine problem.
    Essential Links:
    May 2014
    Washington State
    10
    Gotcha, I am also moving my pool away from an area where there were a LOT of pine needles dropping into it. I have a good test kit and will test daily. Regarding the pump though. Is it sufficient? Most of the sand filters I've seen are double the flow.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    The Intex cartridge filters/pumps are very weak, even though it is rated the same as the bestway sand filter/pump you will probably see better performance from the bestway. The filter is free, hook it up and try it out and see if you like it. Be sure to run the sand filter through a backwash and rinse before setting it to filter. That way any nasty water in the filter will be pumped to waste instead of into your pool.
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Washington State
    10
    Thanks for the help. I set up the old pool and it looks like I have a lot more room for a pool than I thought. I will try to find an 18' or 20' for a decent price, and that will put me around 8 hours for a full cycle which is a bit higher than I want to go. The 2100gph intex sand filter/pump combo is on sale at amazon for $96 with free shipping right now if anyone is interested.
