Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Ta help
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Ta help
    What does it mean if the solution turns red after adding the R008? Isnt it supposed to turn green? The Ph is less than 6.8. This is for a friends pool. Never encountered that before
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    This means his pH is critical low. There is Zero TA. The pH needs to come up immediately. I would begin adding Soda Ash (washing soda) NOT baking soda until you reach a mid 7 pH. What kind of pool is this?
    Essential Links:
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    Its an IG. I have to measure for gallons. I have the soda ash. The cover just came off
    Vinyl liner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    Ok, we can help figure it out with some dimensions if you need it. Covered you say? I'm really wondering what happened then. Better Vinyl than plaster, but I have no idea how much that hurts vinyl or not. Obviously not good for a plaster pool.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Ta help
    Just curious, why not baking soda?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Re: Ta help
    If you start out adding baking soda your TA usually ends up too high by the time you get everything back under control.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    And because the low pH is what does the damage. If you get the pH in range, some TA will come with it, and you can tweak it later.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Ta help
    Think of pH as the main tuning knob and TA as the fine-tuning knob. You first want to go to the right channel (adjust pH to recommended levels - mid-7's) and then bring the picture of the selected channel into sharper focus (adjust TA to the point where pH stays relatively stable within the recommended range).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    I never thought of it that way Bo....that has me thinking of TV in the 70s.
    Essential Links:
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    I can tell u he was dump chlorine in last season and as long as the water was clear that was it. I'm teaching him the TFP method
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    Keep us posted, I'm really curious how this goes. Good luck with your friend, maybe you can bring him around.
    Essential Links:
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    As of now he put in 55oz of soda ash and then 5lbs of ph +. He did test using the drop test phenol red and its showing yellow. I'm suspecting his chlorine is too high still. It came out to about 20,000 gallons roughly.
    Re: Ta help
    Measuring the TA is a good way to get a sense of how far you still have to go. If the PH is being raised with soda ash and PH +, the PH should start being measurable at roughly the time the TA gets up to 70.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    I cant believe it was that bad. Thank u
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Ta help
    I can. No control like that and things can go wildly out of bounds.
    Essential Links:
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    so far he has put in 55 ounces of soda ash, 5 pounds of Ph+ and four pounds of borax. he is telling me Itis still yellow, is that possible? maybe he got a bad batch of droppers
    Re: Ta help
    The worst ta that I have seen was about -200. That means that, just to get to zero, I had to raise the ta by 200. If it turns red immediately, the ta is zero, or even less than zero. Therefore, yes, it can take quite a bit of bicarb or ph increaser to get a reading on ta and ph. It took over 100 lbs of bicarb just to get a good ta.
    Do you have the T100 or k-2006?
    Support the site
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    I do, but he has to buy one. Told him he can't wing it with a pool. I just ordered refills for my T100. I'm doing the pool math according to his drop test pics. Trying to get Ph to turn peach atleast.
    Re: Ta help
    Are you getting a ta reading yet?
    What is the cya?
    Support the site
  20. Back To Top    #20
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Ta help
    The good news is that the TFP method had my pool ready to go in 3 days!
