Results 1 to 9 of 9
Thread: CYA....
    Apr 2015
    Boardman oh
    18
    CYA....
    Hello,
    This is our first pool. Inground, 27,300 gallons, Hayward 245 sand filter. It came with the house we just bought. Why does it take so long for the CYA level to show on the test? I used the sock method, it's been 4 days and it's still not showing anything. We started at 0 and added 1.5 lbs per the bottle to raise the level to 30 ppm. Can I assume it's at 30 even though it's not showing yet and start slamming?? Our pH is at 7.4
    OHpool
    27,300 gallon IG vinyl liner
    Hayward GM 245 sand filter
    Taylor complete FAS-DPD K-2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA....
    Yes you can if you are pretty certain your pool volume is correct. If you think that's pretty close, the go ahead and proceed.
    Welcome to TFP by the way!
    Essential Links:
    Apr 2015
    Boardman oh
    18
    Re: CYA....
    Thank you!!!
    OHpool
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,442
    Re: CYA....
    Ok, I could just be confused, but it appears to me that you'd need to add about 7 lbs of CYA to raise your CYA from 0 to 30 in a 27K pool.
    If not, someone please tell me what I'm doing wrong.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: CYA....
    It can take up to seven or eight days to show up. I think it is because since it is granular it needs to very thoroughly mix with your water to give an accurate reading.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    May 2015
    Reading, PA
    12
    Re: CYA....
    Quote Originally Posted by Jimrahbe View Post
    I hope you're not wrong. Mine's about the same size and I had figured just like you...about 7 lb. Only put 5 in at first, though, cuz I've been reading the forums and got crazy paranoid about adding too much!
    So, that's good news for the OP. You didn't add too much!
    AG 28700 gal (21x41 oval 4-6 feet deep)
    Pentair Warrior 88 DE filter/Hayward 1.5hp 2-speed pump
    Testing w TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: CYA....
    Nothing wrong with taking it up in stages.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Re: CYA....
    Quote Originally Posted by pooldv View Post
    With all of the high CYA posts on this forum, using caution when adding CYA is a good thing.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Jul 2014
    Bedford, TX
    7,442
    Re: CYA....
    The OP said "We started at 0 and added 1.5 lbs per the bottle to raise the level to 30 ppm. Can I assume it's at 30 even though it's not showing yet".
    I assumed that to mean he thought that 1.5 lbs of CYA would get him from 0 to 30ppm, not that he was taking it up in stages.
    I agree 100% that moving up in stages, and not overshooting, is the best way to add CYA.
