Thread: Vacuum the pool...
    Apr 2015
    Boardman oh
    18
    Vacuum the pool...
    when you vacuum do you put the filter on a diffrent setting or leave on filter? We have a Hayward sand filter, inground vinyl pool. After vacuuming is done do you backwash?
    OHpool
    27,300 gallon IG vinyl liner
    Hayward GM 245 sand filter
    Taylor complete FAS-DPD K-2006 test kit
    Fleck's Avatar
    Mar 2015
    Jacksonville, FL
    37
    Re: Vacuum the pool...
    I think it would depend on the size and quantity of the waste. If you were vacuuming a swamp, it would probably be wise to vacuum to waste, whereas if you had some dirt collecting and maybe a leaf you would vacuum to filter.
    AG 18k gal 28' circular pine straw collector, Hayward S220T, Power-Flo Matrix 1.5 HP
    Zodiac Ranger cleaner w/ Twister and a PoolSkim
    12" red, green, yellow, and white beach ball
    K-2006
    Jul 2014
    Peoria, IL
    389
    I usually vacuum to waste. Only because I have a bit higher CH and CYA than I would like and it gives me a way to do small drain/refills. But Fleck's advice is the way to go if your chemistry is where you need/want it.
    As far as backwashing, that I do when the pressure gauge tells me that it is needed.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Apr 2015
    Boardman oh
    18
    Thank you! It is a swamp lol I'm skimming leaves from the bottom and I can't see anything. Hopefully, once I start adding bleach to slam I will be able to see the bottom and get them all. I just need the CYA to register on the test. It's been 4 days and the black dot is still visible. Does it actually take a week? I used the sock method.
    OHpool
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    You might want to get the hayward in line leaf canister with removable mesh bag.
    I wouldn't vacuum without one now after owning one for a few months.
    saves the need to clean the pump basket out.
    Dolphin E10 Cleaning Robot.
