Thread: Light junction box
    May 2015
    Anderson, SC
    2
    Light junction box
    Hello board. First post. I have recently moved into a new house with a pool. The previous owner told me the pool light has "never worked". I pulled it out and started investigating. I'm not getting any power to the fixture. I have power at the breaker and leading down the conduit into the ground. Seem like the problem would be in the junction box. Problem being I can't find it. Any suggestions? It's not under the diving board, behind the diving board in the grass, by the pump, or anywhere it seems. Romex cable is connected in the panel and a SO type comes from the fixture so there has to be one somewhere. The wife is not happy with the holes I'm digging up in the yard.
    Thanks
    Re: Light junction box
    Welcome to TFP!
    Sometimes, especially on older pools, the junction box is installed directly in the deck. Another possibility is that it got buried by a renovation at some point.
    Jul 2014
    Peoria, IL
    389
    So it is good out of the panel and dead at the fixture with two different types of wire. I just looked at a house the other day (we are moving) that had the box buried level in the concrete decking as Jason mentioned. I would assume you would have found that.
    Really have 3 options. Dig and follow the romex until you hit the box or a splice. Use a metal detector to try to track the wire if it is buried shallow enough. Or call a tool rental place and see if they have an underground utility locator. The one by me had them last year.
    Where is the switch for the light at??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2015
    Anderson, SC
    2
    Quote Originally Posted by bdex View Post
    Thanks for the replies. The switch is near the panel box right off my deck. Pump is on the other side of the pool. I'm thinking the utility locator is going to be best bet.
    Jun 2012
    western NY
    1,562
    If it is truly romex wire then some digging will be in order any way if you can not pull it from the conduit. Romex is not rated for wet location (anywhere outdoors including inside conduit) and most likely is the reason the light is not working. Hopefully it is connected to a GFCI breaker. Are there any light switches around that you don't know what they control? How about a receptacle, GFCI or otherwise that it may be connected to.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
