I just installed a circupool chlorine generator. It says it can produce 3.1 pounds of chlorine per day. I am guessing that is at 100% and pump running for 24hrs. Is that 100% chlorine? The dichlor I was using is a 99% product with 56% available chlorine. I am used to adding so many oz of dichlor to the pool to raise the chlorine level. By using the pool calculator I can see the results of adding a certain amount of dichlor or any other chlorine. But what is the result of running the pump and the generator at 100%. I'm running pump 24hrs a day what should I set % at for an initial setting?
