Thread: #'s of Chlorine generated?
    HuskerFan_1's Avatar
    Apr 2012
    Nebraska
    45
    I just installed a circupool chlorine generator. It says it can produce 3.1 pounds of chlorine per day. I am guessing that is at 100% and pump running for 24hrs. Is that 100% chlorine? The dichlor I was using is a 99% product with 56% available chlorine. I am used to adding so many oz of dichlor to the pool to raise the chlorine level. By using the pool calculator I can see the results of adding a certain amount of dichlor or any other chlorine. But what is the result of running the pump and the generator at 100%. I'm running pump 24hrs a day what should I set % at for an initial setting?
    20'x40' inground, vinyl 38,000 gal. Auto Cover. Sand filter 300#. 1 1/2 hp pump. Pentair master temp 250 heater. Circupool Si60 chorine generator. TF-100 test kit. Borates--life is good😎.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: #'s of Chlorine generated?
    The pounds are Chlorine gas. And believe it or not, poolmath has that listed as an option under Effects Of Adding Chemicals. Do some ciphering and figure out how many hours you'll need to generate enough. Then look at how many hours the pump and SWG are on, and then get the SWG percentage that way.
    Apr 2012
    Nebraska
    45
    Thanks for the quick response I found it in the pool math.
    I thought that by running the chlorine generator it would raise the pH over time, but the Effects of Adding Chemicals in pool math show that if I ran for 24 hrs at 100% for my pool size I would lower my pH by .96.
    Is there a difference for adding chlorirne gas and the chlorine generator?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The swg aerates the water as it creates the chlorine, so that raises your ph.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,370
    You would only lower the pH if you were bubbling actual chlorine gas in the water, like some pool services do.
