Thread: Anything New I should try?
    May 2014
    Burlington, NC
    45
    Started SLAMing on last Monday, 5/11. Have been diligent (at least 3 times a day) to keep FC at 12 with a CYA of 30. PH is at 7.4. Has gone from dark slimy green to light brownish green to light green to sea green to blueish but seems to have stopped "improving" in color and can still not see the bottom of shallow end. Pretty cloudy looking too and foamy. Started with probably 38 gallons of 12.5% liquid shock and am almost out. Brushing and trying to vacuum when I can get the hose to work.
    Anything new I should be doing or is it right to "just keep at it?" Suggestions welcome and thanks.
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Anything New I should try?
    just keep at it.
    It took a while to get to dark slimey green, and will take a while to get it back to sparkly blue.
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Nope, keep it up. The more often you can test and adjust per day the better. Brush once a day to help stir things up and keep the pump going 24/7.
    Support the site
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Sounds like your on the right track. Is all the bulk of the organics out. When you vacuum, is it to filter or waste? What is the filter pressure doing?
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    May 2013
    Fort Lauderdale, FL
    423
    Foamy is strange. Can you post a full set of test results? Sometimes a full SLAM takes weeks. Is the pump/filter running 24/7? Backflushing only when needed?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Can you update with a current complete set of test results? note pH will likely read high due to the high FC
