Results 1 to 10 of 10
Thread: New Hayward H400 propane - smells like burning fuel @ ignition
    Jun 2014
    New York, NY
    13
    Heater is brand new. Just fired it up but shut it down the second it smelled like "jet fuel" exhaust. Manometer reading shows the correct pressure for gas. GPM water flow from the pool is good.
    Not sure if this is normal for a new heater on startup and if I should just let it run or not.
    Any advice is appreciated.
    G
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New Hayward H400 propane - smells like burning fuel @ ignition
    Welcome Garvin,
    It sounds like it's the "new" burning off. Albeit a different brand I noticed that about mine.
    Essential Links:
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Oils from the manufacturing process more than likely.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2013
    Erie pa
    68
    If its a propane heater it is probably the smell of burning money.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Jun 2014
    New York, NY
    13
    So I let it run for about 2 hours. The smell was there the entire time. Just smelled somewhat like diesel fuel exhaust but there was no smoke. It basically added 1 degree every 30 mins. I looked in the heater's "sight glass" and the flames were blue and around the right height.
    My old Hayward H200 didn't ever smell like this. It's bad enough to make me want to operate it only when no one is around. I can't imagine having this going when there are swimmers present.
    So something seems wrong. Not sure where to go from here.
    Any help is appreciated.
    G
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Have you contacted Hayward?
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    They do have a noticeable smell when new. It should go away within a day or two. However, it wouldn't hurt to ask the manufacturer.
    Support the site
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The smell is common and will go away with time.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As others have stated, the smell is likely caused by oils from the manufacturing process - it's quite common. I would give it at least 10 hours of runtime. The smell will eventually go away.
    Quote Originally Posted by Garvin123
    Sounds like your heater is set up properly and is burning at the proper air-fuel ratios.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    You ought to get a whiff of a new catalytic converter burning off. They spray 'em with shellac or something so they stay pretty in storage. Probably the same thing you're getting.
