Thread: Is Bigger Better
    April's Avatar
    Apr 2014
    KY
    138
    Is Bigger Better
    Pentair Dynamo 1hp pump
    Pentair Sand Dollar SD-35 100lb Sand Filter
    1 return
    Pump and sand filter hooked up with hoses (fixing to hard plumb)
    400 ft solar heater
    I'm having a couple of issues with my sand filter. Instead of putting a $100 into my sand filter I thought it may be better to just go ahead and replace it with something bigger.
    Would a bigger sand filter clean better? ( I have to keep a sock in my skimmer at all times now)
    Is my pump big enough to run a bigger filter?
    Does Hard plumbing make a difference on flow?
    I appreciate any help or advice. I have researched pumps and filters but don't understand a lot about what would work best. I'm thinking a Hayward would be easier to find replacement parts instead of the Pentair.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    38,237
    Re: Is Bigger Better
    A bigger filter will allow you to go longer between cleanings, but no necessarily filter "better".
    Are you backwashing when the pressure rises 20-25% over the clean pressure?
    Yes, your pump should handle a bigger filter
    Yes, the hard plumbing makes a big difference in the flow rate over the corrugated hoses.
    April's Avatar
    Apr 2014
    KY
    138
    So hard plumbing is better. Right?
    My filter usually runs around 18 clean. I backwash when it gets around 23 or 24.
    I usually backwash for at least 2 minutes then I rinse for 1 minute. Where my pump is only 1 speed it pumps a lot of water out quickly so I normally have to shut off the pump after and fill the pool back to the proper level or it will suck air.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You might want to fill up the pool higher and the. Backwash. Rather than a set time, it's better to BW until the water coming out is clear. Otherwise your are leaving things in the filter. You would have to get a feel for how much extra water you may need, but that's better than timing it. If 2 minutes is all it ever takes to get clear, that would be fine, but make sure.
    Essential Links:
    April's Avatar
    Apr 2014
    KY
    138
    I keep the water level almost at the top of the skimmer. I figured any higher may not get the particles off the top of the water. (I could be wrong).
    If there was a way to put some kind of clear pipe ( if they make one??) on the backwash so I could see when it runs clear. I think that would work good. As of now can't see thur the black hose and then it runs under ground to the back of my property. So I try to look at the water when it comes out of the line but hard to tell if its actually completely clear on the ground.
    If there is a better way to set it up I appreciate any recommendations.
