Results 1 to 9 of 9
Thread: New pool owner in UT
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    Hello all,
    I just recently bought a home here in northern UT that has an in ground pool. It is roughly 20' x 40' and ranges from 3' to 9' deep. It is using a Hayward super pump 1.5hp, a Hayward sand filter and the Chlorination is provided by a Compupool chlorine generator.
    I look forward to doing a lot of reading and a lot of learning here and possibly even help someone out some day (once I know what the heck I'm talking about).
    At this point I have opened up the cover, raked out the leaves, had a solar heating array installed and repaired some leaking gaskets on the diverter valves and the Compupool unions. It's too cold to swim here still, but I figured now was a good time to get it up and running and get the old water circulating again. My Compupool read out is asking for more salt so I am researching the proper amounts to add and how to properly test the current levels so I don't overshoot my target.
    Cheers!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,028
    Re: New pool owner in UT
    Hi KineKilla,
    welcome to TFP. You've come to the right place to figure out how and what to do.
    In order to know the condition of the water, first and foremost, you need a reliable test kit. This without doubt will be the best investment you can make in your swimming pool. TFP recommends either the TF100 or the Taylor K2006. Teh K2006 is available a lots of places online and teh TF100 is available only at www.tftestkits.net and www.poolsupplyworld.com
    For testing salt, most of us use Salt Test Strips which are usually somewhat reliable, or the Taylor K1766 salt test kit (imo, worth the money for the comfort of knowing with certainty), or just depend on the salt sensor on your saltwater controller. If you are comfortable that your salt system is working properly, just add a bag and wait a few hours, then repeat until the system is happy with the salt level. The problem with the add as needed method, is if the salt senser is wonky, you end up with way too much salt and end up having to drain water to get the salt level down.
    Next,
    Get aquainted with what the water parameters are. Clicking the Pool School button is a great place to start. Lots of info in there and no one expects you to learn it all instantly, so if you have any specific questions, please feel to ask.
    Next,
    How to determine how to determine what your chemical levels should be? Well, here you go!
    http://www.troublefreepool.com/conte...mmended-levels
    So Next, of course
    How much of something to put in the water in order to obtain recommendations? Well here you go! A handy tool to help you with that!
    http://www.troublefreepool.com/calc.html
    I hope this helps get you on your way with learning how to care for your pool.
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Dave's given you some good advice and I will underscore the importance of getting one of the Recommended Test Kits. Accurate test results are the cornerstone of the principles we teach.
    I would also check out the
    ABC's of Pool Water Chemistry .
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Well hello there in chilly Utah! You will love your pool once you get to use it. It is SO much fun and relaxing! I can't wait to see pics of your pool!
    Let us know when you have your test kit and we can walk you through doing the tests.
    Kim
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    I have a test kit but it is not one of the two listed here. I have had the water moving for 2 days around the clock and have put 2 bags of salt in so far but also added a lot of water to bring the pool up to post winter levels. It still says "add salt".
    I used my test kit to run some tests tonight and if done correctly, the numbers are as follows:
    PH 7.5
    FC 4 (PPM?)
    TC 3 (PPM?)
    Total Alkalinity 150
    Acid Demand took 2 drops of reagent to bring it down to 7.2
    Still need to get a kit that will allow me to test for CYA and some salt strips. Water is crystal clear, no odors but does need a good vacuuming if I could get a break from the rain long enough to do it.
    I have read the Pool School stuff and am using the TFP Pool Calculator.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Yes, it is ppm. What is your water temp? If it is under 60 then don't listen to the SWG yet. It doesn't read salt level correctly at cold temps.
    KineKilla's Avatar
    May 2015
    West Jordan, UTAH
    53
    I'm pretty sure it is below 60 but I'll need to make sure. That is good to know though.
    DFW, TX
    24,516
    Nice pool!
    Casey's Avatar
    SW PA
    10,461
    Great pool and welcome!
