Thread: Pool Patio Cleaner
    Pool Patio Cleaner
    Any advice on the best soap/cleanser for the pool patio? You know some of it will end up in the pool, so I need something very mild that won't damage the filter, heater, etc. Thanks!
    20k gallons
    In ground plaster pool
    Pentair C420 filter, Pentair Whisperflow 2hp
    Spa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    Re: Pool Patio Cleaner
    I use a chlorine dilution 4:1 and a broom.
    If you have a power washer, then that would be even better. A good power wash does miracles for a patio and deck.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree with dave, pressure washer with a spinning deck head like this does surprisingly well with just water, and maybe a bit of bleach.
