Thread: Aquarite with NO FLOW
    May 2015
    Miami lakes Florida
    1
    My Goldline Aqua arite chlorine generator reads NO FLOW, and its running. As a result is not generating. What could be wrong? Please help. Thank you. T-Cell 15
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Aquarite with NO FLOW
    Welcome to TFP!
    Could be clogged filter reducing water flow, could need to be cleaned per the owner's manual, could be a variable speed pump with rpm set too low.
    Update your signature with your pool info and we might have some more ideas. SETTINGS upper right and then EDIT SIGNATURE lower left.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Hi ez,
    Pooldv gave some good advice on checking your waterflow.
    The problem could also be a bad flow sensor, but first, make sure that you dont have a clogged filter or some other impediment to the flow.
    Divin Dave,
