Results 1 to 7 of 7
Thread: Wiring an Intermatic timer
    May 2015
    NY
    4
    I am trying to wire an Intermatic T101R201 which has a heater control that shuts off the heater 20 minutes prior to the filter cycle time. I have a three wire coming from the panel, I am only using 2 wires and keeping the service 110V, hooked to a 20A breaker. The filter and pump wires can be seen in the picture coming up from the bottom of the timer. Heater wire is on the left and Pump wire in on the right. The feed is coming from the side of the box on the right.
    The only instructions provided are on the cover of the timer and are not clear to me where I am hooking the heater too. Can someone help me with some explicit directions to which wires are going to which connection points( A, 1, 2 or the two black wires on the right of the panel.
    Thanks for the help
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Wiring an Intermatic timer
    Welcome to TFP!
    Call a friend who's an electrician. If they can't help you out, bite the bullet and hire one to come out and wire it for you. Shouldn't take them much more than 10 minutes and then you know you're not going to burn your house down.
    Someone else on the site might be willing to accept the liability of telling you how to wire it... but I couldn't sleep on that.
    Isolated Spa - 345 Gallons
    Mar 2014
    Gulf Breeze, Florida
    66
    http://waterheatertimer.org/pdf/Inte...ion-manual.pdf
    That switch is not designed to POWER the heater but just tie in to the on/off switch on the heater.
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
    May 2015
    NY
    4
    /Users/admin/Desktop/IMG_7861.jpg
    Thats the diagram inside the timer.
    I could get power to the heater inside that timer?
    But I am running a additional two wires to tie into the on off switch?
    I have a Raypak heater P-R106A
    May 2015
    NY
    4
    Hey Chris,
    Am I correct in my thinking after looking at that manual, that I can put my three neutrals (white) on A, the hot from the breaker (black) on 1 and the hot from the filter and heater on 2. Then do my appropriate grounding of each of them, and then use two additional wires to run to the heater on/off to the fireman switch.
    Mike
    May 2015
    NY
    4
    Quote Originally Posted by chawkins99 View Post
    Hey Chris,
    Mike
    That sounds right.
