Results 1 to 15 of 15
Thread: Back swimmers or boatmen help...algae? Slam?
    May 2015
    Savannah, GA
    62
    Pool is 1 week old tomorrow but wasn't full til Sunday.
    I've watched and tested regularly. Just got my levels right shut pump down last night. Woke up to swimming bugs. So far I've seen 3. Caught 2 and pitched out.
    Do I need to slam? Buy algaecide? Or what.
    We have graduation party here Sunday. I don't want swimming bugs or algae!
    Here's my current test results. Pump was off from 12 am-7:45 am
    9:44am 5/20/15
    FC 5.5 was 2.4 at 8:54 am added 52 oz bleach according to pool math
    pH 7.8 was 7.6 at 8:54 so it went up.
    TA 125 same
    CH 60 same
    CYA maybe between 15-20 cloudy when I test but I can still see the dot when sample vial is full. Still waiting to see if I need to add more. I think I might.
    I need advice.....these swimming bugs are right where the ladder is. I'm too short to scope the rest of the pool and I'm not getting in. Lol. Help please.
    24 ft round 52 in deep Evolution CLX 13,000 gal, hayward S180T sand filter & 1 hp Power-flo Matrix single spd, TFP method BBB, taylor K-2006 kit
    24 ft round 52 in Evolution CLX 13,000 gal, Hayward S180T pump sand filter & 1 hp Power-flo Matrix single spd, TFP method, Borates Added, Taylor K-2006 Test Kit (Rincon/Savannah,GA)
    Re: Back swimmers or boatmen help...algae? Slam?
    Bugs are not related to algae, and SLAMing won't really help. Adding borates in the 30-50 range usually gets rid of them.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    hate to tell you this but water bugs like water and because they ride on top of the water ( I think thats what your saying ), chlorine is not really going to do anything... maybe try scooping them out with a leaf rake?
    May 2015
    Savannah, GA
    62
    I read in another forum they feed on algae and other organisms. Incorrect???
    May 2015
    Savannah, GA
    62
    I got out what I could, found a few of both kinds of bugs in the skimmer basket and filter basket.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    I've had problems with those bugs in the past and they do go away when the pool is completely rid of algae. I believe you are correct that they are attracted to algae and when there is none to feed on, they leave. The ones I've had do not stay on top of the water. They are little divers and can stay under water a long time.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    May 2015
    Savannah, GA
    62
    The ones I see are diving and staying and coming up for air. There's 1 or 2 more that are fast and don't want caught. I just need to know slam or add borates???? What to do???
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would SLAM. If it were me.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Savannah, GA
    62
    Ok where do I find how to slam??
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Under pool school. Here's the direct link:
    http://www.troublefreepool.com/conte...tain-shockingl
    Jun 2010
    Alabama
    17
    I have had problems with the backswimmers, or whatever they are called. High CL2 levels will not affect them so SLAMing will have not help. I have tried many times. Best way that I have found is to use the leaf skimmer and catch them, then squash them. I haven't tried the Borates as I had dogs that drank out of the pool in the past. May try it now though. I have a small pond back behind my house and believe that is where they come from.
    Oh and they will put a nasty little bite on you as well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    How high of a FC level have you exposed them too, and for how long?
    Essential Links:
    May 2015
    Savannah, GA
    62
    FC level has been between 2.6 and 5.5 right now it's 4.6. I've tried to maintain between 3-4 due to unknown CYA level.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    ya high chlorine will not keep them away.
    I had left my pool open all last winter with a maintained FC of 27 and I saw a boatman or 2 when the water was 45 degrees.
    Dolphin E10 Cleaning Robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Slamming is not going to help. You only need to SLAM if you have something organic in your pool consuming chlorine and cannot pss the OCLT. My chlorine usually stays in the teens and 20s all winter also.
    I have some bugs in my pool and skimmer baskets pretty much all the time. I have some weird little bugs sometimes that hang out just below the water line on the walls. i don't know what a backswimmer is. I googled it but a lot of different bugs popped up in the search. It is just part of the deal. Along with frogs, snakes, snails, worms, caterpillars, roly polys (pillbugs), crickets, june bugs, dogs, dragon flies, kids, horse flies can't think of what else I find in my pool.
    I also have borates in my pool. I would recommend adding borates for more reasons than just bugs.
    The best thing that we have done to reduce bugs around our pool is not to use the pool light and turn on area lights away from the pool and deck. Keeps the bugs over by the lights.
