Results 1 to 11 of 11
Thread: Another newb!
    May 2015
    Dayton, OH
    17
    Another newb!
    Hello all! I've been lurking around here for a while and finally decided to join! I'm Darryl, from Dayton Ohio, and I have an in-ground pool. I look forward to interacting with you guys! I love this site! Lots of good info!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Another newb!
    Welcome!
    And let me be the first to say... Can you post test results?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Another newb!
    Welcome to TFP! There is a ton of information here to help you maintain your pool.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Another newb!
    Welcome to TFP!
    How about putting your pool info in your signature? What to put in your signature
    And give Richard some test results already. He prefers that you describe your chlorine test with either tweety bird yellow, school bus yellow, etc
    May 2013
    Fort Lauderdale, FL
    423
    Re: Another newb!
    welcome! Did you order a test kit yet?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Another newb!
    Welcome and we are glad to have you here
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Another newb!
    Welcome....now we need numbers
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    mnasholm's Avatar
    Feb 2015
    Eugene, OR
    83
    Re: Another newb!
    And pictures are always awesome too!
    Welcome!
    Lomart 18x48 AGP 7000Gal
    Hayward S210T w/Hayward 1hp Power-Flo Matrix Pump 2-Speed
    TF-100 w/Speedstir!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Another newb!
    Hello, Darryl
    ...... and welcome to the forum
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Another newb!
    Welcome to TFP!
    Casey's Avatar
    SW PA
    10,457
    Re: Another newb!
    Welcome
