Results 1 to 17 of 17
Thread: TF100 Chlorine Testing
    Aug 2008
    Fredericksburg, VA
    51
    I'm probably obsessing over nothing, but something's been bugging me about the TF100 DPD test ever since I started using it.
    The instructions say to use a "heaping" scoop of the powder, which seems pretty subjective in the world of chemistry. With such a small scoop and varying interpretations of what "heaping" means, one tester might use as much as twice the amount of powder as another tester.
    So my question...what does a "heaping" scoop of DPD powder look like to you?
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: TF100 Chlorine Testing
    Overfilling the tiny bowl.
    In the FAS/DPD Chlorine test for the TF-100 Video you can see the scoop
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Also, this is not a precision amount. As long as it's really good and full it's ok. Agreed, it could be subjective, but it's ok to be close.
    Essential Links:
    Aug 2008
    Fredericksburg, VA
    51
    Huh...didn't know there was a video for that. Thanks!
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by flipflop View Post
    There are more - Check them out
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You have two options. You can be a two-leveled scoop perfectionist or a heaper. Two leveled scoops using the spoon provided with the kit will be enough. A heaping scoop, essentially one level scoop with another level scoop over the top of it will be enough too. I'm a proud Heaper.
    If you're still concerned, if you have a little bit undissolved after adding your DPD powder, that's enough.
    Isolated Spa - 345 Gallons
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I just watched the video, and realized for the past year, I have been using the wrong side of the blue scooper thing.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by yostmatt View Post
    You're surely not the first and certainly not the last!
    Carlajo's Avatar
    Apr 2015
    Wellsburg wv
    8
    I can't find my scoop!! I've been using the end of one of the girl's hair clips and guessing the heaping amount my scoop used to hold...
    Intex 22X52 Ultra Frame
    Hayward VL Series Sand Filter
    Full Sun, No trees
    Taylor TF-100
    Gorgeous deck!
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Carlajo View Post
    You can buy a new scoop, but at fifteen cents I'd wait until I needed additional reagents of maybe a SpeedStir.
    Support the site
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    What is the actual required weight for the test? Im curious because we have DPD powder at work that we use to test chlorine in out cool water towers and it comes prepackaged in a tiny foil bag. If I remember correctly the directions say that the amount doesn't matter. Is that true? If I do one heaping scoop or one HUGE scoop does it really not matter?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Z7What View Post
    Wayne
    If it is this, yes you can use it. 1 packet for 10ml water.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,251
    You can not really use too much of the powder (within reason of course), but too little can result in questionable behavior/results.
    If the water turns a nice pink color, then you should have enough powder. The only reason you might need more than 1 scoop is if you are trying to test high FC levels (20+ ppm).
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Quote Originally Posted by Azgirl71 View Post
    That is exactly what we have. Only thing is, is that out powder is for 25ml samples.
    Wayne
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You could test with 25 ml. I don't recall the number to multiply by. It may be in the extended test kit instructions on here.
    Lisa
    38,251
    25ml makes the test 0.2ppm increments.
    Or use half a pack in 10ml of water
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    It is in post 4 in this thread. Says multiply by .2
    Extended Test Kit Directions
    Lisa
