Results 1 to 18 of 18
Thread: Noobie here with pool pics
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Pool built in 2000. Had it refurbed last season, 2014. Plaster was getting pourous and tiles were coming loose, especially at the raised beam under the sheer descent. Changed from white plaster and ceramic tiles to blue/grey plaster with ceramic color quartz and glass tiles. Here are before and after pics. I tried to insert a few in between pics during the refurb, but files were to large I guess. I really need to learn abut this TFP chemical method. Briefly skimmed over some posts and apparently my inline chlorinator with 3" tabs is not the best maintenance method for keeping my pool healthy. I am also using aquacheck select test strips. Dip, wait 15 seconds, get all of your readings in one shot.
    Before...
    After...
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Noobie here with pool pics
    Welcome to TFP. Nice pool transformation (although the "before" pic looked pretty good too from what I can see).
    Quote Originally Posted by JamesR
    ...apparently my inline chlorinator with 3" tabs is not the best maintenance method for keeping my pool healthy.
    Correct. Continued use of tabs will raise CYA levels and necessitate ever-higher chlorine levels to compensate. See Chlorine CYA Chart. This is the most important relationship to understand if you want to maintain a crystal-clear pool.
    We recommend getting a good drop-type test kit like one of these Recommended Test Kits. Test strips do not provide the accuracy needed to properly maintain your pool. The test strips I have seen have wide ranges on what they consider good (e.g., they often call CYA in the range of 30-80 "good"). While that's usually true for a manually-chlorinated pool, a SWG pool will need CYA in the 70-80 ppm range. While a CYA of 30-50 is good for a manually-dosed pool, it is not good for a SWG pool. Plus, knowing that the CYA is between 30 and 80 ppm does not give you enough information on what chlorine level you need to maintain.
    If you haven't already, I would check out ABC's of Pool Water Chemistry
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Looking at your link to recommended test kits, it appears that the TF-100 is the most versatile kit. I will order one of those.
    Jun 2014
    15,096
    Looks nice James. And hey ... definitely take charge of testing on your own using one of the recommended kits. I use the TF-100 with the magnetic stirrer. Not only do I look like a rocket-scientist now, our pool is always clear The TFP way works.
    ffournier's Avatar
    Apr 2015
    Houston Texas
    43
    Wow, that's a beautiful pool and landscaping. Great job.
    25K gal saltwater gunite and Pebble Tech plus built in spa. Features-Weeping rock wall, and fountains. All Pentair equipment. Main pump- Intelliflo 4/160. Feature pump- Intelliflo 2hp single speed. Aux cleaner pump-Pentair 1hp. DE filter, Pentair heater, Glacier GCP210 pool chiller.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Thanks all. I just ordered the TF-100 kit. Read the TFPC for beginners thread and posted a comment at the end of that long topic.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Very nice pool remodel!
    Couple more articles for you to read.
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to figure out how much to add.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome James!
    I like both pools as well, but love the waterline tile in number two. Beautiful, and you're off to a great start. Good to have you join up. Enjoy the forum.
    Essential Links:
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Thank you! You cannot imagine the amount of pool tile and glass samples the wife had at our home when we were re-doing this pool. You could have tiled a complete pool using all of them! I think I had more samples in our dining room that NPT had in their showroom. We are real happy with the glass look against the water color. Gives it an inviting soft appearance.
    ps.... how do I attach another picture? I get a message stating I have exceeded file size. Is there a limit to what I can upload per each topic or for each reply?
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Easiest way is to link to an external picture storage like Flikr or Google+. No limit there.
    Otherwise you can get more space here by contributing to the Website.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    I think the after picture would look even better with a bunch of babes in bikinis lounging around it.
    Jul 2014
    Peoria, IL
    389
    Looks great and I agree 1000% with Richard!!! Welcome to the forum and on a serious note it is so liberating to know the chemistry behind what happens with a very large investment like an IG pool and the effects chemicals have.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    True, but I don't think the wife would appreciate "a bunch of babes" in there.
    ......Honest honey I though they were your friends, I have no idea how they got here.
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    i wish i had a pool like that!! looks great!!
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    Jun 2015
    Dallas, TX
    148
    Question about your new plaster - was it just a regular plaster (no Quartz added or anything) with some color added?
    I really like your plaster color. We're about to redo our pool with a basic white plaster and wondering if I should consider coloring it a bit.
    Casey's Avatar
    SW PA
    10,438
    Wow... so very nice!
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Quote Originally Posted by lvrpl View Post
    So sorry for the very late reply, but it is grey dyed plaster with many different quartz colors embedded into it. Gives it a nice blue/turquoise color in the sun.
    Aug 2015
    N.O., Louisiana
    1
    would you mind telling me what tile you went with. I'm in the design phase of my pool. We are looking for a blue glass and I really like the look of yours. After looking at tile it all starts to look alike.
