Thread: Helping My Neighbor
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Helping My Neighbor
    I live near the New Orleans area, my next door neighbor is originally from New Jersey. He and his wife found it very hard to adjust to the much hotter and humid weather here. To help with this he bought a Intex 15'X48" Metal Frame Pool last year. He always complained how the filter didn't flow much water. A few weeks ago I went and looked at the pump set up and I was shocked to see such a small filter, I was also shocked to see the liner/wall of the pool didn't really support the weight of the hose, the weight of the hose basically pulled at the port built into the liner and caused them to be facing upwards in the pool. Does that make since?
    2 weeks ago he bought a Intex 2800GPM Sand Filter and we installed it. It flows ALOT more water which is great but being as the weight of the hose pulls at the "port" the discharge water almost breaks the surface of the water like a fountain.
    What have yall done to support the hose for the suction and discharge where it enters the pool. Im sure hard piping it would be best but before I suggest that id like to see other ideas to offer to him as well.
    He came by this past Saturday to look at my pool since I been using the TFPC Method, his jaw dropped. He couldn't believe how perfect it was. Once we get all the hardware setup with his, he will be switching to the TFPC Method!
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    22,553
    Re: Helping My Neighbor
    People have used everything from bungee's to ropes to support the hoses. I've even seen a PVC stand to support the hose from the ground. The possibilities are endless.
