Results 1 to 12 of 12
Thread: CYA Test
    Sep 2014
    Elgin, IL
    23
    CYA Test
    My pool is great chemically and is clear. I just loathe the CYA test. Just as the dot MAY disappear, I start to see my reflection on the surface of the testing tube. Hate that. I do the test with my back to the sun, waist level and all that... (And pour solution back in the bottle and retest). My reflected image is cute and all, but to check the dot, I have to lift the testing tube, shift it sideways, or bend forward. Then the dot faintly shows so I continue adding drops. Am I just a narcissist at heart, or is this normal?
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: CYA Test
    there was a post a couple of years ago that i use
    usual back to sun at waist height and minimum of room temperature water
    but fill tube to 100 level then hold at waist level and have a quick look, dont stare at it for ages trying to decide if you can see dot
    then fill to next level and hold at waist level and have a look
    keep repeating until dot disappears with a quick look without staring
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: CYA Test
    I get that glaring reflection too. It is distracting at times.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Aug 2014
    Northern IL
    4,615
    Re: CYA Test
    I get the reflection also. I like my CYA around 30 so the subjectivity of the test is especially bothersome because there's not much room for error.
    Re: CYA Test
    If you move the bottom of the test tube around a little bit while you're taking a reading, you'll be able to perceive the movement of the dot below the reflections on the surface. Our eyes are much better at perceiving motion than perceiving subtle differences in shades of grey.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: CYA Test
    I too have trouble deciding whether or not it's a dot. When you pour it back in the bottle to retry, do you shake the bottle before retrying or just pour it back and retest ? (I sometimes wonder if it's my bald head I am seeing or the dot )
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    30,415
    Re: CYA Test
    I feel everyone's pain. The CYA test is the hardest.......but it gets better with practice.
    Try taking an average....pour it in the first time and if you think the dot is gone, stop the test and note the level.
    Then do the same a second and third time and then average it. I promise you will be surprised at how accurate you will soon be. Also remember to think of the results in terms of 10 ppm 30 ppm, 50 ppm, etc. No further precision is needed.
    Take heart that there is NO better test. All the testing companies use it as the standard. The strips are pretty worthless and the digital testers (ColorQ) often fail badly
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: CYA Test
    Quote Originally Posted by aussieta View Post
    I like that!
    Dolphin E10 Cleaning Robot.
    Sep 2014
    Elgin, IL
    23
    Re: CYA Test
    It's still very frustrating; FC for CYA of 10 vs 30 vs 50... It makes a difference if you're keeping a tight rein, right?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA Test
    The margin of error is as much as 15 PPM, so don't sweat anything with tight control. This is one test where you don't need extreme precision.
    Essential Links:
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    Re: CYA Test
    WOW I did not realize the tube had to be waist high! I've been looking at it from like 12 inches away. Good info.
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: CYA Test
    here are some videos on how to do the tests.
    https://www.youtube.com/user/tf100te...e=results_main
