Thread: Pump Pressure
    May 2015
    Dallas, TX
    1
    Pump Pressure
    We have a 10K gallon, unground pool that was installed 5 years ago. The 1st year was great and then the next 3 we had pressure issues. We had a 1 cartridge pump and after cleaning a new filter the first time the pressure would jump to 15-20 in a few hours reducing and sometimes stopping the output of water back into the pool.
    We had a "pool guy" come out a few weeks ago and he said our pump was too small for our size pool. We bought a much larger pump (4 cartridges) and started running it. Our pool was very dirty and by the next day the pool was crystal clear and we had to clean the cartridges. We clean with a garden hose with some pressure but not enough to loosen the cartridge from the bands. We've cleaned these filters 3-4 times in a 3 week period and only used the pool once so we didn't track too much dirt/grass into the water. We also use an electric pool cleaner which cleans a lot of the dirt.
    So now with a bigger and new pump, clean cartridges and not a large use of the pool we cannot keep the pressure below 12-15. As soon as the pump is turned on the pressure goes to 5 right away and then creeps higher. The company who installed the new pump has already said he doesn't know why the pressure is not staying low after cleaning and is not returning our calls.
    I read a thread stating possibly someone's pool still had a lot of dead (particles/algae???) even though the water is clear. Does anyone have any suggestions on what could be going on. Should we keep cleaning the filters and this should clear itself up?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump Pressure
    I suspect your pool is trying to grow algae, it takse a good bit of algae in the water before it becomes visible, and your filter is likely doing enough of its job filtering out that invisible algae and therefore needing to be cleaned. If you can post a full set of test results we might be able to narrow this down for you.
    Ike
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Re: Pump Pressure
    Welcome to TFP!
    It is likely a lack of chlorine causing algae to grow. If chlorine is not kept above the minimum level for your CYA level algae will grow, Chlorine CYA Chart
    If algae is growing in your pool then you need to SLAM Your Pool.
    Get a test kit from Test Kit Comparison, I use the TF100 from tftestkits.net.
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Pump Pressure
    Welcome!
    Yep - what they say. ^^^ Clogging a filter that fast indicates something is in the water. If you could post some test results, that would help a great deal. I'll go out on a limb and predict the CYA level will be in triple digits. Or the pool store shorthand of "99".
