Results 1 to 8 of 8
Thread: Normal Chlorine Consumption
    May 2012
    Thomasville, NC
    12
    Hello I have been losing about 3ppm of chlorine each day for the past week. My pool is an above ground 13,500 gallons using the BBB method. It gets direct sunlight pretty much all daylight hours. It may get partial shade the last hour or two of daylight. It has been in the upper 80's this past week and sunny. Here are my pool readings, just wondering if this amount of chlorine loss per day is normal for a pool such as mine.
    Water temp 85
    FC 6.5
    PH 7.5
    TA 100
    CH 100
    CYA 35
    CC .5
    The test were completed using Taylor TF-100
    Should I raise my CYA because of the direct sunlight or is this just normal?
    13,500 gallons AG 24' Round, Hayward Pro Series S180t Sand Filter 34 GPM, Hayward Power-Flow Matrix 1.5 hp Dual Speed Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: Normal Chlorine Consumption
    Losing only 3 ppm per day is pretty good if you get a lot of sun. Raising CYA to 50 or so might cut it down to 2 or 2½
    Aug 2014
    Shallotte, NC
    693
    We're near the same latitude and I'm losing 3 PPM/Day in the sun at:
    Water temp 82
    FC 4.0
    CC .2
    PH 7.4
    TA 100
    CH 250
    CYA 40
    BORATE 50
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    The southern sun packs a punch. We use that here on hot days.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    22,550
    I lose about 2ppm per day, most days. However I run my CYA near 60ppm. If you're losing 2 to 3 ppm per day I'd call it good. It's probably not worth raising the CYA just for 1 ppm FC per day. That's only about an extra pint of bleach a day. It'd take a long time to pay for an extra 3 lbs of stabilizer at that rate.
    May 2012
    Thomasville, NC
    12
    Thanks everyone for the replies. I figured that was probably normal just wasn't 100% sure. I'll just go with it. I have been trying to keep the FC at 6ppm and just realized the target was 4.5 - 5 for my CYA level. Thanks again.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I found adding above the target just results in more FC burn off. Just keep it at target range for your cya.
    Feb 2015
    Cypress, TX
    54
    What is everyone in Texas losing mid summer? I have alot of direct sunlight and losing 3 PPM a day is going to require a TON of bleach.
    18k gallon IG gunite/pebblesheen with 3ton moss rock waterfall, 8 ft 12" raised wall & rock accents , 42sq ft 12" raised spa w/ 6 jets & cascading stacked stone waterfall, 3HP Intellifo VS pump,
    420sq ft Pentair cartridge filter, 400,000 BTU Pentair Gas Heater, 1.5HP Whisperflo water feature pump, 1.5HP Silencer Spa Blower, 3 intellibrite lights, EZTouch System 8
