Thread: Is this cap before pump causing air leak?
    May 2015
    Tempe/Az
    12
    Hey, moved in 2 weeks ago and this is my first pool, so this is my first post!
    When I turn the valve in front of the pump towards the cleaner the pump sucks a lot of air. When it's split between the cleaner/skimmer I get the odd bubble in the top of the pump filter and a few out the returns. I tried submerging the cleaner robots hose but that didnt stop it sucking air.
    When it's sucking air there is a knocking from the pipe connecting to this cap, even when its only pulling a small amount of air.
    I took the pump cover off to let the pressure out and tried unscrewing the cap. It gave a little but I didn't want to force it.
    Could this be the source of the air leak? What is it for?
    Am I ok to unscrew it and inspect it further?
    Thanks!
    19k IG Pebble Tec, SWG Hayward Aqua Rite, Pentair Triton II Sand Filter, 3HP EVSS3-NS Motor, Tempe AZ
    May 2015
    Tempe/Az
    12
    Re: Is this cap before pump causing air leak?
    Another thought - when I divert it could it be increasing the pressure enough to suck air through the o-ring on the pump cap?
    I gave it a good clean and it looked in ok condition.
    38,452
    I think that is a check valve, but no idea why there would be one on a cleaner line.
