Thread: New pool build - leaks in plaster
    Mar 2015
    TX
    1
    Are leaks normal for new plaster? I also notice a little yellow in the plaster (it's supposed to be blue). Is this normal too?
    We have an a ton of rain in the Houston area over the past couple of weeks. IMG_4770.jpgIMG_4773.jpgIMG_4773.jpgIMG_4761.jpg
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New pool build - leaks in plaster
    Welcome to TFP Ashley,
    Sorry you're entering this way. I don't know where the moisture is coming from, but it isn't normal. The discoloration is not normal obviously, but that's an issue with a mistake or oversight on the install that allowed that to happen. Have you contacted the builder/installer? I would have them address this before a fill takes place. Sorry I'm not more help, but I can't say what the causes are.
    Essential Links:
    30,405
    What is that darkest spot at the bottom corner of the step in the top pic?
