Thread: A little advice on connecting new pump to sand filter with hose
    I just bought a new pump a Hayward Maxflo XL but when I install it I want to get one of the hoses that goes between the pump and the filter. Where do I get one and the what connections do I need to connect to the filter and the pump? Thanks.
    20x40 Vinyl Lined Inground
    Central GA
    Chem: Bleach/Borax/Chlorine Tablets
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: A little advice on connecting new pump to sand filter with hose
    You probably have to build it with flex-pvc and fittings, most likely 1.5 inch NPT maybe 2 inch
