Thread: Going away for the weekend...
    May 2015
    Monroe/NJ
    76
    So I have a SWG, but it's not working (long story). I will be away for 3 days this weekend. Is there some sort of formula out there about how much chlorine I can/should dump into my pool before I leave so that it doesn't dwindle down to zero before I get back? What about if I go away for a week, again assuming that my SWG is not up and running? Should I just bring it to SLAM levels? Thanks.
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Casey's Avatar
    SW PA
    10,450
    Re: Going away for the weekend...
    Bring it to SLAM level according to your CYA and cover the pool with a solar cover if you have one n shut the pump off.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Last time we were out of town, I had one of our friends come over daily to feed the lizard and feed the pool. My pool usually consumes 3 ppm on a sunny day, so I just had them pour in a half gallon a day while we were gone.
    You could do something like that, or even throw a few trichlor tabs in a floater. Super chlorinating won't guarantee you'll have some FC left when you get back.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Depending on your cya, you could do a floater of tabs as previously said.
    May 2015
    Monroe/NJ
    76
    Thanks all- CYA 40 and climbing.
    Didn't want to have to buy floater and tabs given I have a SWG (frustrating!) but may not have a choice...or may just try Casey's SLAM recommendation as will only be gone for 3 days.
    Heat Pump
    Dec 2014
    West Hills, CA
    157
    Your cya isn't that high. You may HAVE a Swg but you really don't unless it works. I'd float the tabs if it were me. Juicing up the pool w chlorine will work of course....but what if you're gone longer? Maybe you can have someone....ANYONE , dump some chlorine for you one of the days. That is the only problem w this whole way of doing things if you don't have a Swg.
