Thread: Hayward SWG reading zero salt and not generating - could cell need replacing?
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    Hello all...
    Yes, back again. Replaced the pump as per my question last month (haven't updated sig, so ignore that!).
    Now, got a problem with my 2-year old SWG. Have done the acid/water cleaning as often as the "check cell" light comes on. Now, that light is on steady, the "generating" light is off, and the system reads zero instant salt (low salt light is on). May be worth mentioning that the "No flow" light is off, so it seems to sense that water is moving along.
    Naturally, by the time i noticed, green was creeping in. LC took care of that, but now need to get the SWG back on track.
    I'm assuming the cell needs replacing (lasted all of two years). Should I take it to the PS to test? Or just replace and hope everything goes back to normal?
    As far as replacement, should I stick with Hayward cell? Other acceptable options?
    As always, thanks in advance.
    Manny
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1 HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    Re: Hayward SWG reading zero salt and not generating - could cell need replacing?
    Semi-stupid follow-up question..... should I always reinstall in the same direction after removing/cleaning, or should it be flipped around?
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    Upon further reading, here's two numbers which are likely relevant:
    Voltage = 30
    Amps = 0.
    So, it's done - now to replace!
    Amazon? OEM? Seems like that was the recent consensus in another thread...
    Those symptoms don't match up with the cell needing to be replaced. More likely the current limiter has burned out. A search on the forum should turn up a fair bit about how to replace it.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Has the cell been removed and cleaned. The sensors could be calcified. May need a acid clean. Refer to the manual. Testing the cell at a cell testing station will eliminate the cell being the problem.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
