Thread: Anyone near Kannapolis NC
    Kannapolis, NC
    89
    Hope this dont get me banned but, I have to ask. I have test kits however I have just not been able to master the cya test and I am close to opening, and would love for someone to watch me and see if I am doing it correct or heck check it for me.
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Anyone near Kannapolis NC
    Have you watched the video? https://m.youtube.com/watch?v=NxaqoW-_MCs
    You can also order a standard solution that is 50ppm CYA to evaluate your test technique http://tftestkits.net/R-7065-CYA-Sta...ution-p34.html
    This is one of the more difficult tests, so don't feel bad that it is troublesome.
    May 2015
    TN
    312
    I feel the same way as you Bowlin!
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Orlando, FL
    690
    Here is another link that provides detailed information. The CYA test is near the bottom. http://www.troublefreepool.com/threa...Kit-Directions
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Sep 2013
    Charlotte, NC
    41
    Hi Bowlin, I am in Charlotte, this is just my second season with a pool but if I can be of any help, just let me know.
    26K gallons, IG vinyl, Pentair 1.5 HP, Hayward DE filter, TF 100 test kit, Ecojet Turbo Cleaner
