Thread: New Plaster & New To TFP - Bleach?
    off2theocean's Avatar
    Sep 2014
    North Carolina
    12
    Hi -
    This is my second summer in a new house with a pool. Last year, I had no idea what I was doing with the pool - and it showed in the water. Algae, calcium deposits, just about everything bad you could imagine. The old pool was also due for a new plaster job.
    Luckily, I found this site over the winter while on my info-quest for new plaster. The new plaster on the pool was complete last Saturday and the pool was filled by Tuesday. The PB did the start up and gave the usual instructions - brush, vacuum the dust and watch the PH.
    I have started to use the new TF-100 test kit and am trying to get a handle on everything. I have read through what seems like zillions of posts.
    There is almost zero plaster dust in the pool - there wasn't really in the beginning either. Weird. My PH is through the roof. I keep adding Muriatic Acid and that seems to bring it down, if only for a while.
    When I first tested, my FC was 8. Now it is almost non-exsistant. I have a puck feeder and have added chlorine tablets. I have also added one tablet in each skimmer. Nothing is bringing up the chlorine. I have lots of 6% bleach on hand - ready to use. Do I need to keep using the tablets since it is a new plaster? I am worried about my numbers, damaging the plaster and just about everything else pool-related. I don't want to blow it.
    Here are my numbers from this evening:
    FC 1
    pH 8
    TA 60
    CH 125
    CYA 50
    Thanks!
    Near Winston-Salem, North Carolina
    33,000 IG Freeform Gunite * Pentair Tagelus Sand Filter * Hayward Pump
    1970's Build * Resurfaced 2015 w/Krystal Blue Krystalkrete
    Polaris 380 Cleaner * TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: New Plaster & New To TFP - Bleach?
    pH rise is to be expected with new plaster. You will be adding a lot of acid for a few months then it will slow down, but still be elevated usage for the first year.
    Your CYA is already at the top end of what we would recommend for a non-SWG pool, so i would stop using those tabs. Liquid chlorine products only.
    I would suggest an Overnight FC Loss Test (OCLT) to see if anything organic is consuming the chlorine. Prior to the test remove all pucks and add 4 gallons of bleach which should get you up around 10ppm FC. When the sun goes down take your first FC reading. In the morning take your second reading and compare the difference.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Definitely need to change to bleach/liquid chlorine which is the same thing just different percentages. Bleach is usually 8.25% and liquid chlorine is usually 10% or 12%. I pick up Kroger store brand plain old bleach at the grocery store when it is on sale.
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to figure out how much to add.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    You've gotten good advice, so I'll just say enjoy your time on TFP.
    Essential Links:
    Sep 2014
    North Carolina
    12
    Thank you all for your advice. I will switch to liquid and stop using the tablets. Hopefully, I will be on my way to a TFP kind of summer.
