Results 1 to 9 of 9
Thread: What do I correct first?
    Liberty Square's Avatar
    May 2015
    wilkes barre PA
    5
    I received my professional Taylor Kit today, and did all the tests. It is amazing what I am learning after 25 years! I have a cloudy pool that will not clear, and now everything is making sense as to why.
    Here are my first set of numbers.
    PH 7.8
    FC 0.4
    CC 2.2
    TA 330
    CH 0 (stayed blue so soft water?)
    CYA 45
    My guess is that I have to:
    1. Lower the PH to get my TA down,.
    2. add some calcium to raise the hardness
    3. and I positively have to SLAM the pool.
    I am just not sure in what order I should do all of this.
    When I was at the pool store a few days ago, he did say that my CH was 0 and I confirmed it with my test. He wanted to sell me an expensive bag of calcium to raise it, but I remember one time before I used “Quick Joe” calcium chloride (for ice melt) and that worked fine.
    Thanks for any advice!
    Sean
    Sean @ Liberty Square
    20X40 Inground Liner
    Hayward EC65 DE Filter
    Hayward Natural Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: What do I correct first?
    Fix pH and SLAM. You have a vinyl -lined pool, so you have no worries about leaching Calcium out of the plaster. Don't waste money on adding it, unless the water foams after it's clear.
    The other alternative is to use Cal-hypo instead of bleach for the SLAM. It might not be cheaper, but you'll get fewer strange looks wheeling a pail of pool chlorine out to your car versus thirty jugs of bleach.
    Casey's Avatar
    SW PA
    10,423
    I would absolutely not worry about the calcium. I don't even know what my CH is.
    Fix the pH and SLAM the pool!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Here are some intro Pool School articles to read
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to figure out how much to add.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!!
    You'll be amazed then. What we teach here will have you very happy about how much easier and different simple pool care can be.
    Glad you joined us.
    Essential Links:
    May 2015
    wilkes barre PA
    5
    OK I got the PH to the correct level and started the SLAM. When I tested the sample, I wa amazed that the FC is still so low. I am having a hard time getting the FC to the right level, but the CC is off the wall! I remember you said that this is normal because the alge eats it fast at first. so I just keep adding chlorine until the break point? really scary.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Liberty Square View Post
    Early in the SLAM test and adjusting every hour speeds things up. As the chlorine begins to hold yu can spread the testing and adjusting out.
    Support the site
    May 2015
    wilkes barre PA
    5
    Thanks Tim! It is begining to work. FC is rising as I add liquid clorine, and the CC is beging to fall. this is cool!
    May 2014
    Franklin, NC
    9,184
    Amazing when a plan comes together. Keep it up.
    Support the site
